I checked and all 4 support arms are fine and Springs are not broken. The corner brackets are not broken and the tub is level. However, it doesn't take much effort to push the tub down until it bottoms out. It worked fine until today. What's happening.
SOURCE: Fisher & Paykel "clog Problem"
the water comes through 2 vavle 1 for washing and the other for rinsing more than likely that the rinse valve is down it will need replacing thats the more common fault for washers not rinsing
SOURCE: Fisher & Paykel Washer Model GWL11
Clebinla,
I have the same problem with our GWL11. It just started yesterday. I think I found out where the problem is occuring. I noticed that there seems to be a crack in the small rubber tube that supplies the fill water. The water leaks out of this crack and runs down the back of the machine. I fixed the problem temporarily by putting a piece of plastic below the cracked tube that funnels the water into the tub. I am trying to locate a replacement for the tube but I haven't had much luck yet (it is a curved yellow tube that is a couple of inches long.)
SOURCE: Fisher & Paykel GWL11 Top-Load Washer troubleshooting
I've had my washer for about 8 years. I experienced the same problem - pump stopped draining the machine. I called F&P and "Patrick" told me that I need to 1) unplug the machine, 2) tilt up the front of the machine, 3) spin the pump (plastic blades) until they turn freely (usually counter clockwise) but I turn it both ways till it turns freely, 4) plug the machine back in and press the buttons to get it back where it was - this has worked every time to get the machine going again. I do a lot of "dog laundry" and I'm sure the rugs/dog hair cause the problem. Hope this helps!
SOURCE: Fisher Paykel gwl11 washer leaking and squealing
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
SOURCE: Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
