Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
82 FXRS that won't start
When I push the start button I can't hear the the relay clicking, but doesn't turn starter. I changed the battery, no help. Am I looking at replacing the starter or the solenoid or could it be something totally different?
Thanx!
  • 23 Answers
I have an 82 FXRS as well. I love it even though it has a vibration that comes and goes (motor mount issue most likely.) I would check for broken/loose connection on the solenoid before I started replacing components. I'd check the switch as well. Can't really reach the solenoid to jump it direct. Check the small stuff first.
Posted on Aug 17, 2009
There is a start relay behind the left side panel. two allen bolts to remove. mine was just tie wrapped replacing this relay made my start button work again. I had a push button bypassing this. and found a relay looking for starter and ordered it. fixed
Posted on May 15, 2014
1986 yamaha xj700 won't start just makes click
sounds like a bad earth if you have jump leads go direct of earth to engine to see if this cures it if so you no where problem is clean replace earth
Jul 12, 2013 | Motorcycles
BMW K 100 LT won't start
is starter relay...under tank there is an electrical box with relays there...look for the relay( I think it is green) that has the wires from the battery to starter motor and bridge these wires at terminals...this will tell you is the relay is working ...if it just goes click click click then battery is RS
the buzz you hear from fuel tank when u press start button is fuel pump
Jul 04, 2012 | 1987 BMW K 100 LT
Why does the 30 amp circuit breaker behind the battery box on my 1990 fatboy click once when i push the ignition button? The bike won't start.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
Mar 08, 2012 | Motorcycles
2002 hyundai Santa fe will not start. I turn key and starter turned for 3 seconds then stopped and now when i turn key NOTHING. I hear a circuit sound in back of car when i turn key but no other sound. ...
Definitely a starting system problem. That sound you hear in the back is the fuel pump.
Starting system circuit components (besides wiring harness)
1. Ignition Key Switch - closes the starter relay control circuit to energize the relay and close the contacts inside the relay (you can check this by locating the relay in the underhood fuse/relay box and have a friend turn the key while you listen/feel if the relay 'clicks'
2. Starter Relay or its Contacts
3. Starter Solenoid - pushes/pulls the starter gear into the engine's flywheel ring-gear and its contacts close to provide battery power to the starter itself.
4. Starter itself - poor brush contact with the armature's commutator will prevent the starter to spin/turn
If you are 'Electrically' talented, you can check to see if you're getting battery power to the starter solenoid by using a simple 12 volt test light/bulb. Connect one lead to the starter solenoid terminal and the other to chassis/engine ground and have a buddy turn the ignition key - if the light turns 'ON', then you know that particular circuit is OK but the starter solenoid is not energizing to push the starter gear into the flywheel ring-gear to turn the engine over. If it doesn't, the problem is elsewhere (wiring, starter relay, starter relay control circuit, etc).
You can have a qualified Hyundai Service Technician properly diagnose your vehicle. OR, you can Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, illustrations, etc.
Aug 25, 2011 | 2003 Hyundai Santa Fe
I have a 1997 Yamaha Big Bear that won't start with the button, can hand crank it with the starter cord and it will start - very hard to pull over cause I have a bum arm. I'm thinking it could be a...
you could be right about the starter relay, start with a test light and check the power at the relay. then if so check power at the switch if good make sure that the power is getting back to the relay if so replace your relay. let me know what you find and if you need help
May 23, 2011 | Yamaha DT 360 Motorcycles
How do I check ignition modular on 2000 dyna ? My bike will not turn over, have new coil regulator, stator, was running good now it won,t start?
If not turning over check for power at green wire plugged into starter / selinoid rt side. when you have key on & start button pushed. & when you push button do you hear relay click..if not check fuze,, I have got good help on the forum.. harleytalking.com .. good luck..
Mar 31, 2011 | Harley Davidson FXD Dyna Super Glide...
Having starter problems on 2002 Honda shadow 600cc. Batter is fully charged, lights work when key is turned on. Only clicking noise heard when starter button pushed. Able to push start, and runs...
check starter relay first this will be the part thats clicking and will have two thick battery leads on it,,,if you short across the two thick battery leads the starter should turn the engine over,,if this works change the relay,,if nothing happens when you short the two battery leads across then its a starter fault
Aug 18, 2010 | 2002 Honda VT 600 CD Shadow
Gentlemen, I have a 1979 580c backhoe, proud owner for 3 weeks now. But it won?t start. Here's what I've done so far. 1.checked the starting circuit, the neutral switch is good. 2.I have continuity...
It sounds like you have a bad starter. You can try bringing 12v direct to
the starter just to be sure(be sure it's in neutral) or use a volt meter at
the starter while somone turns the key. You have checked the wire's
and all appears to be ok, the only thing left that would draw the meter
into the red is the starter itself. I hope this helps.
May 23, 2010 | Garden
86 FXRS won't start
pull your right side cover and locate starter relay pull spade connector 1 at a time squeeze them with a pair of plyers to asure good contact put them back on sometimes it really is that simple
May 29, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
261 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
