Air conditioning wont come on - Heating & Cooling
  • 864 Answers
Is it plugged into a working outlet? Plug a lamp or other electrical device in to confirm that the power is on. If not on check the fuse or circuit breaker in the power panel and replace/reset if required. If using an extension cord make sure it is a grounded heavy duty one designed specifically for use with air conditioners. Set the temperature knob for maximum cooling. Once the unit starts you can adjust the knob for the desired level. Make sure the fan or speed knob is set to ON or High. If it uses pushbutton controls press each of the buttons all the way in pressing the ON or COOL button last. Dose the fan run alone if set to FAN or Exhaust setting? If it does but the compressor will not start for cooling, then there is a problem with the compressor that a service technician will have to evaluate. If none of the above works, please leave a comment with more specific information. Thanks,
Posted on Jul 29, 2009
My frigidaire air conditioner wont turn back on
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you are having prolonged air conditioning check out Air Conditioning Tamarac for more HVAC Support.
Jul 23, 2016 | Frigidaire Heating & Cooling
Air condition flaps wont work in 2006 oldsmobile 88
Sounds like a vaccum problem from the switch on the dash to the controls w/ dash vents
Apr 17, 2013 | Air Conditioning and Heat for Oldsmobile...
Front air conditioning, wont direct to lefty sie
its the flaper in duckwork under the dash switch from heat to air when u turn the slector switch its a job to fix.
Jul 30, 2010 | 2004 Chevrolet Suburban
My wife was driving our vehicle with the air conditioning on and went into the store upon going back she noticing the air conditioning isnt working and wont blow air....solutions?
sounds like the blower motor has packed up ,or a fuse or overheated wire ,reostat packed up ,any of these faults will cause this sort of problem
Jul 04, 2010 | 2006 Chevrolet Silverado 1500 2WD
Wont turn onwhen i plug in.
the control might be bad or the power board...you will need to check this first.....
Apr 03, 2010 | Goldstar KG6000R Window Air Conditioner
Air conditioning stuck on vent
the mode door motor is bad
Aug 18, 2009 | 2005 Jeep Wrangler
1994 BMW 318i Air conditioning problem
You need to check the blower motor in car ...
Good luck..
Jan 15, 2009 | 1994 BMW 3 Series
Air condition pum
Yes, it should, just means you wont have air conditioning.
Jan 14, 2009 | 2002 Jeep Liberty
Air conditional
Reset the error by disconnecting the supply for 10 sec. and " on " again, test the unit. If it wont work just call a tech, to fix the problem.
Apr 14, 2008 | Heating & Cooling
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
