Question about Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Belkin router 7230-4
Hi?, i have a problem with my router, can't get my wired computers to work? wired computers not working, 1,2,3, and 4 led stays on all the time?
Help....
  • alexjg Nov 25, 2007
    well, i did ipconfig on my computer, and can't see the router, nor be able to configure it, the thing is that i don't have compueters connected to router and still the LED's for wired computers are ON, recap;... this router was working perfectly well, all of a souden..., just stop.
  • 54 Answers
Do an ipconfig (cmd-ipconfig) and see if the router is assigning your PC a 192.168.2.x address If not, perform a hard reset on the router and try again until your PC gets a valid local 192.168... address. When an ip address is asigned reconfigure the router with dhcp enabled
Posted on Nov 25, 2007
Here's my problem, I have a belkin n300 extender, ok it worked for about a week or so and one day I lost connection, when I looked it is solid blue, even after I press reset or wps, it stays blue, I don't...
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Mar 07, 2018 | Belkin Computers & Internet
My wireless link led is off. the ethernet outputs are working
1.open the router
2. get a tester
3. remove the led bulb that is not working (because to led sometimes breaks because of to much blinking
4. test it if it work
5. or if busted replace it
6. the important thing is its working
7.if you cant open it try bringing it in a computer shop
Mar 16, 2011 | Netopia (3347NWG-VGX) Wireless Router...
My DLink DI-604 router is not working properly. Lan port 1 I think is not working and only one computer connected to the router can connect to the internet. So I tried to remove all ethernet cables,...
Having an issue with your router or other equipment rented or purchased from Verizon Fios? Contact customer support service number 1-800-243-0019 for help. Our technical experts.
Apr 15, 2017 | D-Link (DI-711) Router
No wi-fi signal transmitted
There is a reset button in the back of your router, which will reset it to all default settings. Try this to get the router to work.
Also is it hard wired into another computer? Check it out that way. make sure the router is working.
good luck
Apr 13, 2010 | Linksys WRT54G2 Wireless Router
I have a 2 wire wireless router. Both computers
you should your lan to ruter cable install it again carefully.
Feb 20, 2010 | 2wire (1000-400108-001) Router
1 of the 2 computers cant get online
Pleaase check if the PC connects when plugged directly to the DSL or cable connection whatever you have without the router in between. That would ensure the functionality of the ethernet card on the other pc.
Feb 10, 2009 | NetGear MR814 Wireless Router
Yellow light on - N series router
the yellow light is for processing data
Jan 12, 2009 | Linksys Wireless-G Broadband Router
No power led, wlan led blinking
well, what you could try is unplugging the power source from the cable modem, and the router. wait about 1 minute. then plug everything back in and wait.
i remember having this problem as well, but i think the problem with me was that my wireless computer was too far away from the wireless router, not saying that your too far or not, but that what i had, so i just pitched the wireless adapter, and created an ethernet connection. just sharing my experience.
Feb 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
Belkin 5D3230-4 not working at all
Try and update your firmware on router,and see if that helps, you can go to belkin website to do that, look up your router and download firmware, call belkin they will help u install it
Feb 05, 2008 | Belkin (F5D7230-4) Router (587009)
Laptop keeps disconnecting then connecting every so often.
Has the computer ever stayed on long enough to connect to the internet?
Is there a wired computer working when attached to the router?
If not, if possible please try to connect the laptop wired to the router as a test and tell me if it works.
I am trying to determine if your router works with the internet before considering the wireless connection simplying the initial problem. Once the router works wired is time to try the wireless. Once the wireless works unsecured you may want to change the router and wireless adapter to secure the wireless network. So this can be a three step process.
Jan 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin F5D7230-4 Kit (F5D7230V4SNPDQ) Logo
69 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
