Question about IOGear GPSU21 Print Server
Getting IOGEAR GPSU01 to work on Vista 64
Tried same solution as for GPSU21 but it did not work. Any alternatives?
  • 30 Answers
If you know the IP address of the print server you can create a TCP/Ip print port. IOGear offers direction on how to create this type of port and here is a link.
http://www.iogear.com/support/faq/id/297
Posted on Sep 25, 2009
4 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: IoGEAR printserver GPSU21 with VISTA
Yes, the GPSU21 is tested to work with Vista 32 and 64-bit Operating System. The things you need to do is listed below:
1. There's no need for you to install the CD that came with it, if the MFP Utility is already installed in another computer.
2. Get the IP Address of the GPSU21 from the computer that has the MFP Utility installed.
- Open the MFP Utility > locate TCP/IP at the lower portion of this window and click the plus (+) sign. > get the IP Address.
3. After getting the IP Address of it, go to your Windows Vista computer and ping the IP Address (just to make sure that Vista is seeing the Print Server).
- To ping, follow the steps below:
- Click the start menu and open the MS DOS Command Promt.
- On the black screen, type this "ping (type the IP Address of the print server): just like this
- C:WINDOWS\Desktop\Scott>ping 192.168.x.x and then hit enter.
4. Once you get ping statistics 4 packet sent; 0% loss. Then the Print Serve is communicating with Vista.
5. On you Windows Vista computer, make sure that the printer is working when directly connected to it. Because there could be a possibility that the printer driver is not properly installed that's why the server is not working.
6. On Vista, go to the Control Panel > Printers > Locate the printer icon (the one that is set as you default printer)
7. Right-click on the printer icon and then select properties > go to Ports tab.
8. Click on Add port button > select Standard TCP/IP > click on "New Port" (beside Cancel)
9. Hit next > type the IP Address of the print server. > Next
10. Click on Custom > Settings button
11. For Protocol: select LPR
12. For the Queue Name: type L1 > Click on OK > Finish.
13. Then under the printer properties, you will see the Standard TCP/IP is selected
14. Hit Apply so that the printer name would appear right next to that port > OK
15. Try printing a test page.
NOTE: After following the steps, you should be able to print using your Vista computer. I configured this print server with Vista several times and it does work with Vista.
Posted on Apr 07, 2009
  • 5384 Answers
SOURCE: Print server Iogear GPSU21 + HP Deskjet F4180 do not print!
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: http://iogear.com/files/pdf/GPSU21_Printer_Compatiblity_List_4-20-09.pdf . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
I hope this helps.
Posted on Jan 28, 2010
firesnake09
  • 2923 Answers
SOURCE: IOGear GPSU21 doesn't work wirelessly with ip4500.
First, you have to make sure that the printer can print directly connected to the computer.
Second, make sure that you can "ping" the print server while it's connected to the router.
If the printer works when connected to the computer and you can ping the print server, then you just need to change the port in the print server utility. It should be set to LP1 and not LPT. The queue name should be set to L1.
Check also the printer port, and be sure that it's set to USB001 or USB002 Virtual Printer Port.
If same problem occur, try to uninstall and re-install the server utility. Use the link below to download the utility for Vista 64-bit OS:
http://www.iogear.com/support/dm/driver/GPSU21#display
You may refer to the user manual of GPSU21 or call IOGEAR through 866-946-4327.
Thank you and good luck!
Posted on Jun 02, 2010
Testimonial: "This is very close to the work around I got from Iogear support. This is very helpful and informative and it works"
Iogear GPSU01 DRIVER FRO WINDOWS 7
Try this it may help.
Download and install XP mode as a virtual machine. Which should solve the all
too often problem related to no being able to find a WIN 7 or 64bit driver.
FREE from Microsoft. I use it and it works great
http://www.microsoft.com/windows/virtual-pc/download.aspx
Selvol
Feb 02, 2012 | IOGear USB Print Server, 1-Port [ GPSU01 ]...
Iogear print server not compatible with windows 7
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Oct 22, 2010 | IOGear GPSU21 Print Server
IOGear GPSU21 doesn't work wirelessly with ip4500. Laptop running vista home 64
May 24, 2010 | IOGear GPSU21 Print Server
I am using A Iogear gpsu21 with a Kodak esp5 printer. I am able to print with no problem from a Acer AS1410 laptop running win 7 32 bit.I am using a Sony Vaio E series laptop with a win 7 64 bit system i...
First, make sure that the Kodak printer driver is properly installed in your Sony Vaio. Make sure that you can print while the Kodak is directly connected to Sony Vaio.
If you can print directly connected to it, try to reinstall the GPSU21 Utility.
Apr 13, 2010 | IOGear GPSU21 Print Server
I hope this helps.
Jan 26, 2010 | IOGear GPSU21 Print Server
The software supplied on the disc doesn't run on Vista 64
Here is a direct link to the software download page.
Sep 09, 2009 | IOGear GPSU21 Print Server
What's the problem if the printer power's up but cannoyt print?
Have you installed the correct drivers on the PC? What OS are you running (XP, Vista, Linux)?
Jun 10, 2009 | IOGear GPSU21 Print Server
Feb 19, 2009 | IOGear GPSU21 Print Server
Iogear SAYS the driver works for 64 bit but i keep getting an err
The drivers for a 64 bit version of Vista will almost never be the same as the 32 bit version.
IOGEARs website does not list a 64 bit driver for your device.
Jan 19, 2009 | IOGear (GBU211) Bluetooth Wireless Adapter
Does IOGEAR GPSU21 work with Vista?
before running the PS Wizard in Vista, right-click on the icon for PS Wizard and select "run as administrator". This will clear the bind errors and wrong segment errors many times - this only applies to vista.
May 09, 2008 | IOGear GPSU21 Print Server
IOGear GPSU21 Print Server Logo
1,131 people viewed this question
Top IOGear Computers & Internet Experts
castletech
castletech
Jose Velazquez
Jose Velazquez
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
