SOURCE: 1990 montero no start. No power to open injectors, good fuel pump
Check the injector pulses with an osciliscope. If you arent getting a pulse check the ecu. I have cooked 2 of them. One killed my ignition but had good fuel. the second time it wouldnt open the injectors but had good spark. A quick check is to take the ecu out and take the cover off. then look for burnt electrical components.
SOURCE: Toshiba Satellite 1405-S171 dead screen; external
Unless your screen's hinges (pivots) are busted, the video cable ain't gonna come loose on its own.
But if you have to check, it's underneath the keyboard. Remove the plastic strip above the KB, after that, it's three screws (L, middle, R), and you can lift up the keyboard. The video cable is the big bundle right behind the DVD drive.
SOURCE: apps lib was not working
Same here, come on archos at least post an aknowledgement on appslib! Day 4 of owning the device, don't let me down after choosing *you*.
Archos 101 user
SOURCE: 2009 chevy hhr, driver side
check the window lock switch on the drivers panel, if its gone bad, the other windows will not work,,
