SOURCE: AC pad not fully getting saturated with water
1. Make sure the pump is getting plenty of water.
2. Make sure the pump is working.
3. Check the pvc pipe with drip holes are not plug. (above the pads )
4. Check the pads directional arrow that should be facing up. When pads are initially installed you can see arrows on the pads. The arrows should be in the up direction. That will allow the pads to get saturated more efficiently.
I hope these steps help you.
Jerry,
SOURCE: evaporated cooler is not filling up with water
yes ur water pump is not working properly..
ur will have to check it
SOURCE: need replacement pads for mastercool mrc55wa
These pads are available in different sizes and styles at home improvement stores like LOWES or HOME DEPOT (in season)
SOURCE: Our Bonaire Evap Cooler stopped after power failure
you need to turn off power supply to unit that works ok and leave other unit switched on and code it and test it then switch other unit back on
cleaning is recommended. Check the water distributor, making sure it is clear and free from blockage. Failure to do so may lead to uneven water distribution and therefore less efficient operation. Do not hose Celdek with high pressure.
