Just fixed the ac on the truck ,now the front panels don't blow any air at all.What is the problem?
    President:
  • 3,433 Answers
Blower fan seems to be inoperative. Thhis can be a fuse issue.
Posted on Jul 29, 2009
2000 ford expedition ac works in front but the back wont turn on
You do realize you have a leak to be found & fixed,
if you had to add refrigerant. All your doing now,
is waiting for it to leak out again & polute the air.
What kind of shop adds to a leaking system & does
not check the rear unit as well?
If you ever have any fuse found blown, there is a reason it failed
Replacing a fuse won't fix a thing,they blow for a reason
Jul 19, 2013 | Cars & Trucks
Heat or ac don't blow air out vents
My a/c doesn't blow air through the front vents just through the sides andbottom
Jul 31, 2012 | 2004 Chevrolet TrailBlazer
What's your problem?I have a 1996 Chevrolet Suburban. The AC is blowing out hot air. I have had the truck for 6 years, every Summer its the same thing. The ac does not get cold, I take it to the m
To clarify - - if the truck has rear and heat, you have two heater cores and two evaporator cores. The evap cores carry the freon.
If the leak is in the evap core in the front, the price is probably right.
Jul 06, 2012 | 1999 Chevrolet Suburban
My Audi 2005 Air con system will not blow cold air is this anything to do with the vent at the front of the vehicle that creates an airflow
Well, I don't know. I would have to see the car.
Generally, as long as air can flow thru the condenser and radiator, the ac system can produce cold air.
As for the interior, you normally pull in outside air and cool or heat it, but you can also recirculate inside air which would close off the outside fresh air intake for the cabin.
Jul 01, 2012 | 2005 Audi A4
Ac control panel in front quit blowing air at all. middle control panel and rear work good still blow out cold air. please advice
needs blower motor or blower resistor if it blows on high then it is the resistor if not then it is blower motor
Sep 06, 2010 | 2005 Chevrolet Tahoe
AC and heater works fine, but no defrost and floor air. Air blows out the front panel only. how do i fix this?
this is due to a disconnected or broken vacuum line going to the ac panel, it should be located under behind the engine on the cars firewall. it will be thin about 3/16 of an inch in diameter.
happy hunting
Oct 29, 2009 | 2003 Chevrolet Cavalier
Rear AC is ICE cold but front blows Warmer air
a plugged orifice will prevent the front from becoming cold
Sep 01, 2009 | 1999 Chevrolet Suburban
98 ford explorer AC isn't blowing out of the front vents
can't help you w/ fuse panel diagram-- but it may be your front blower motor door. sometimes they stick in the closed position. good luck!!
Jul 07, 2009 | 1998 Ford Explorer
My heater stopped blowing this morning.
Your heater blower fan unit is in need of replacement.
It's a difficult job so take it to a service center.
Jan 29, 2009 | 2002 Chevrolet Tahoe
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
