Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Changing lamp how do you change the lamp. Does it require taking entire back of tv
Before doing the following you must unplug the TV for 30 minuets to allow lamp to cool down. The front mid panel pulls off. You will see a "finger screw" (not sure what they call it) that you loosen and then slide lock level to the left. Remove that cover. On the left side is an Allen wrench screw. Unscrew that and pull lamp casing out. Might be a little stiff because of power connector, but it comes straight out. Simply place new lamp casing in & put everything back.
Posted on Jan 23, 2008
Six red flases ruile is the thermo fuse
Posted on Nov 26, 2007
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Our tv will not turn on. The pwere button flashes for a little while and then the lamp indicator light turns red.
Tv have not change the projection "LAMP" the last 2 years and tv on an used like 4 or 5 hours a day in?The tv LED "LAMP" flashes or staying on.The projection lamp,life are over.Require changing a new projection lamp.
Nov 03, 2010 | Hitachi 60V500 60" Rear Projection...
I have a rca d52w20 rear projection tv that has sound but no picture what may be the problem
When was the last time the tv projection lamp was change in this tv?The projection lamp in the tv now,if 1 1/2 or 2 years olds,tv on an in uesd like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.Hear alot of clicking too?The board call the Ballast board also require changing.This Ballast board help to ingnite the projection lamp.
Aug 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
It shutts off ramdomly the red lite blikes an have to what for green light to come on before it turns back on
Tv "LAMP" LED lite indication flashes or staying on?The tv projection lamp life is over.The projection lamp require changing.
Aug 06, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Aug 02, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
The power will not turn on and the power LED is flashing red.
PT-50LD54 is an LCD rear projection TV with a consumable bulb that wears out normally after 2-5 years of use.
Most likely you need a bulb. That is first step in any troubleshooting for that tv. Check out Panasonic Gallery to identify lamp and replacement bulb.
Changing bulb involves removing the lamp assembly and replacing the bulb in the lamp assembly. Like doing a puzzle. Requires philips screwdriver, pliers and patience. Don't have jam on your fingers when you do it.
easyab
Apr 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
After replacing tv lamp cartrige for my tv Mitsubishi WD-52725, the timer green light keep flasing and tv would not turn on,
Please check the installation, the lamp door is not placed correctly or still open. this is causing the door micro switch to stay open. take out every thing and put it back exactly the wat it was before you changed the lamp. it is slso easy to by pass this switch if required.
Mar 08, 2010 | Televison & Video
Recently changed my bulb for my Wega LCD KF-42SX300U TV. Since then it is turning itself off, with no particular pattern. It can come straight on and last for a few seconds, or last the entire evening....
This is a classic case of a faulty lamp(even though it is new). Possible that it is a ballast(lamp power sply) problem but it is more likely that the lamp doesnt quite meet the required specifications. Your lamp may be a Non-OEM or a refurb. You should try to get it exchanged with the vendor you bought it from.
justlamps.com is a great source for bulbs.
good luck
Jan 07, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Need to change dlp bulb...where is the housing? do i have to take entire back of tv off? obviously, i'm missing something. thanks.
Just pull off the lower front panel it just pops off the one under the screen. Then the lamp door is on the left behind the panel you poped off.
Jan 02, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
