Question about Yamaha HTR-6130 Receiver
Audio doesnt come thru my hdmi cable from the dvd player. And video doesnt go thru hdmi cable to projector. Have to run rca cables to both
    Problem Solver:
  • 9 Answers
This system only passethrougt video on HDMI cable, to get sound u need to connect another cable: rca or optical.
Video: from system to projector, check cable or select direct sound... in this case i dont know what is the problem...
Posted on Sep 09, 2009
    Problem Solver:
  • 9 Answers
    Problem Solver:
  • 7 Answers
Hi there
Check your DVD players' settings/manual to ensure the HDMI port is the default output port. Also confirm that both audio and video are enabled on that HDMI channel as it can be separated to be only video or only audio in a lot of cases.
Confirm you are at least getting video out from the DVD with a direct connection to your projector with the HDMI cable.
If video is making it to the projector direct from the DVD, you will need to confirm your amp is monitoring the HDMI input if there isn't a specific input selection for it. Connect your DVD to the amp and your amp to the projector and test again that you are still getting video AT LEAST. This will help narrow down which device is not playing the HDMI game if you still have issues at this point.
To sum up;
Confirm HDMI is the default output from the DVD for both audio and video.
Ensure you are getting video AT LEAST with a direct test to projector.
Confirm your amp is monitoring the HDMI input coming from the DVD.
Hope this helps.
Posted on Aug 18, 2009
Pyle troubleshooting
The projector has built in speakers.
Aug 06, 2014 | Pyle Home PRJHD66 1080i Front Projector
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
No sound coming to the speakers.
What is the model number of your receiver?
Many receivers don't support audio over HDMI, they just switch the signal from hdmi-in 1-4 to hdmi-out, but can't analyze the data to take audio out of it. Your receiver is probably one of those.
You need to connect the DVD player also via spdif digital cable. Look at the player to see if it has optical (square black plug) or coax (orange RCA plug) connector. Receiver probably has both of them.
Feb 27, 2010 | Audio Players & Recorders
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
No HDMI output with Panasonic SC-PT950
Change the video out settings from your system
Dec 10, 2008 | Sony DAV-S400 System
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Yamaha HTR-6130 Receiver Logo
325 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
