Question about Maxi-Cosi Baby Gear
I need to replace the plastic part around where the long belt comes out at the front (which tightens the straps) as the belt has been pulled hard in upwards direction and the plastic covering the roller mechanism has broken. Where can I replace this part?
  • 419 Answers
You should contact www.maxi-cosi.com who will be able to help you.
I hope this helps.
Posted on Sep 15, 2009
1999 Dodge Caravan 3.8L: I need to change the serpentine belt tensioner assy. Do I need to remove the alternator to access the tensioner assy 15mm mounting bolt ?
the nut that holds the tensioner on is under the alternator and would be much easier to remove with the alternator out of the way.
Jun 05, 2011 | 1999 Dodge Caravan
How do you wear the parents of invention ultimate ring sling?
Adjust the wide panels over both your shoulders and lower back to ensure that you are comfortable and that your child is carried safely,then bring the thinner straps around just over your chest through the loops/rings and pull tight as if tightening a belt around your waist. be sure the straps are secure and it should hold tightly with no give.
Aug 01, 2010 | Parents of Invention Ring Sling Baby...
How can pull adjustment belt
The shoulder straps feedthrough a loop in the adjustment belt so when you pull on the belt it tightens the straps. When you say it came out, if it has come out completely then you will need to remove the car seat and locate where it connects to the shoulder straps before feeding it back through the hole again
Aug 15, 2009 | Maxi-Cosi Baby Gear
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
REmoving carseat cover to wash
I too have had this problem. I'm not certain that my model is the same as yours. Mine was purchased new in 2002 from Babies are Us and was approx. $250. Though color doesn't matter, mine is a brown houndstooth with a micro fiber faux suede. The way I finally did this..... as the above contributor noted, their are four difficult places to release...all are where the straps go through the fabric. Two are near the seat and two are near the shoulders. The two near the seat are held by plastic casings that should pull up about a 1/4 inch when pressure is applied. This gives you just enough room to work the fabric around these plastic pieces and remove. This is tight, but should not require ripping the fabric. Work from the narrow end first. Slide the fabric as far over as you can and then work on it like you were undoing a very tight button and button hole. The ones near the shoulder do not unbutton this way. Here, I had to litterally pop the casings free. I did this by applying even pressure on the whole cloth unit and pulling away from the actual car seat. The plastic casing pulled free of the unit and allowed me to free the cloth. I washed the cloth in the washing machine and hung to dry and it did very well. I agree that for the price we paid for this chair, it should not be THIS difficult to free to launder.
Oct 05, 2008 | Baby Gear
Car seat straps
I have the same problem with mine. It's an easy fix. Unlock the straps (pull the little gray release tab) and then pull firmly upward on the lap belt opposite the loose strap. To reword: If your left shoulder strap is the loose one, go the right side of the seat, where the LAP belt comes out of the seat, and pull firmly upward on that part of the belt. It will pull the slack out from the other side. I hope that was helpful.
Oct 02, 2008 | Graco ComfortSport 8431
Nania Nuevo 3-in 1
hi,
i just had the same problem but there seems nothing out there at all, so i had to try myself and just succeeded there.
so a little step by step guide, i hope its clear enough.
1. i found taking the whole thing apart to be the easiest way. so take it apart, you should have two long straps, two metal buckles, and two plastics things you will need at the end.
2. hang the strap with the shoulder pads around your neck, the way it would lie if around your child.
3. note two whole, one on either side of the seat, inside, near where your childs bum would be. imagine the other strap, the long one coming from there(imagine we are starting form the right here), then it goes through the right buckle.
4. next it goes through the right shoulder pad
5. now in real life it would go thorugh the back of the seat, but its easier to leave this last, in case you pull it through lopsided somewhere, so you can fix it, anyhow....
6. the long strap now goes around your neck and through the other , the left, shoulder pad,
7, then it goes through the left hand buckle
8. lastly, it WOULD go through the hole on the inside left of the seat.
before you do that thought, close the buckle and see if everything is straight
9. now pick one end of your work and pull it through one of the holes in the back of the seat, once its thorugh one hole it should go through a thinner grey strap at the back, this is for tightening the whole thing at the fornt once your child sits in the seat, once thats done pull it back out front through the other hole.
10. lastly, pull the long ends of the straps through the two inside holes either side of the seat, they should come out at the bottom, the two plastic green things are then attached to the ends. there is a right and a wrong way here, one way you can pull them in tight, the other you cant
i hope this works for you and i hope i made sense....
Antje
Mar 22, 2008 | Nania Nuevo 3-in1
Evenflo journer
on the back of the carseat the are black plastic holders the straps go threw and there is a part in the middle that you push down and you pull the front staps to loosen or the back straps to tighten
Feb 17, 2008 | Evenflo Journey Premier Stroller
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Baby Gear Logo
59 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
