SOURCE: hdmi
I have just purchased a Philips DVD Home Theatre System HTS8100 (Soundbar), HDMI, ambisound, etc. When I play some DVD's though I get the message "wrong region". What does that mean and how do I solve it. Also why do only some DVD's come up with that message.
SOURCE: Samsung lcd hdtv won't receive signal from fios hd receiver
Hey nothingsfree,
You may not necessarily have anything incorrectly set up, but there are a couple of things that I would suggest trying.
First, you'll want to make sure that your TV is set to the correct input source. Some TV's will require that the input source be changed in order to display any signals from an external device, like your HD-DVR. This can typically be done by accessing the main video menu using your remote control.
According to information provided by the manufacturer, you should be able to change the input source for this model TV (Samsung LN46A750) by doing the following:
* Press the "Menu" button on your remote control
* Press the "Up" or "Down" arrow button to select "Input," then press "Enter"
* Press "Enter" to edit the "Source List"
* Highlight the signal source for the HD-DVR, and press "Enter"
Next, you may want to try updating the TV's firmware. In some instances, simply updating a TV's programming can eliminate any potential hardware or software conflicts between two devices. To update the TV's firmware you will need access to a computer and a USB flash drive. Step-by-step instructions and the firmware update itself are available through the following website:
http://www.samsung.com/us/support/download/supportDown.do?group=televisions&type=televisions&subtype=lcdtv&model_nm=LN46A750R1F&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=02010100&disp_nm=LN46A750
Make sure to read all the warnings and disclaimers available though, as your TV may already have a more up-to-date firmware version than the one that can be obtained through Samsung's support page.
Should neither of these address the issue, you may wish to see if connecting your HD-DVR to a different HDMI input solves the problem. Much like computers, TV's have been occasionally known to have faulty inputs or loose internal connections.
If all else fails, I’d suggest contacting the manufacturer for further assistance. In many cases manufacturers are able to provide over-the-phone troubleshooting support, in addition to having access to a wider variety of possible remedies for hardware problems.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
