Question about Zebra LP 2844 Thermal Printer
I use direct thermal paper with a black mark at
Some of my customers are using a LP 2844 with direct thermal paper (not a label) with a black mark at the back. The printer is suppose to stop at the black mark but sometimes it skips one or just do not stops at all. In that case, after 4 or 5 receipt it just stop and give an error message. What could be the problem? I know that it can not be the printer, if my customer puts a certain roll in it, it is ok change roll then we have the problem, change back to the first roll and everything is ok again. (the rolls are from different manufacturer)
And I am also looking to find the specification for the best type of paper to use with the LP 2844
thank you
    Scholar:
  • 62 Answers
Compare the 2 rolls, Pay close attention to the position ans size of the black mark. The black mark sensor in the zebra 2844 is not (where you would expect it to be) in the centre of the label. It is about 10mm to the right,
Try calibrating the printer to your labels.
Check my other solutions to see how to perform a manual calibration.
Posted on Aug 01, 2009
What media does the LP 2844 printer use? I have been supplied a roll of labels with-out any code on them. The printer seems to be working but does not print anything. The troubleshooting guide asks if I am...
Hi An Lp printer is a direct thermal printer.
That means that if you rub the label with your nail, you should see a dark scratch.
If you place a flame under the paper it should darken.
The head heat the paper at the positions where printing is performed
Jul 03, 2011 | Zebra LP 2844 Thermal Printer
What is the difference between the Zebra LP 2844 Thermal Printer and the Zebra LP2844Z?
lp2844 use programming languages EPL2, Line Mode, lp2844 use ZPL II, ZPL (Zebra languages), both are Direct Thermal (don't use ribbon), not Thermal-Tranfer (use ribbon).
Nov 17, 2010 | Zebra LP 2844 Thermal Label Printer
MY ZEBRA LP 2844-Z IS PRINTING BLANK, WHAT COULD BE THE PROBLEM?
Since the LP2844 is a direct thermal printer, the first thing to check is to make sure you have direct thermal labels - regular label stock won't work. Just quickly scrape your thumbnail across the label, the friction will cause a black line if the label is direct thermal.
Aug 11, 2010 | Zebra LP 2844-Z Thermal Label Printer
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
Printer is working but labels are blank
you need to have thermal direct labels to print to a thermal printer. heat turns the paper black. check your labels to see if you have thermal direct or tuern darkness up if it is thermal direct paper
May 14, 2010 | Zebra LP 2844 Thermal Printer
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
Hint:
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
Dec 02, 2009 | Zebra Eltron TLP 2844 Thermal Label...
My lp 2844 will not print
Firstly is your label Thermal Direct?(DT)
To test quickly score your fingernail across the surface of the label, if it leaves a black mark then it is DT
If there is no mark then it is probablly Thermal Transfer(TT) and requires a ribbon, which you cannot use on the LP 2844, only on the TLP2844.
If you have DT labels then go into the printer driver via Printers & Faxes and the Printing preferences and change the darkness to level 7.
Try printing again.
If it works then cahnge the darkness again until you get a satisfactory print darkensss.
If it still does not print then change the darkness to maximum, does it print?
If not then I think you have a duff printer, return it to the company that supplied it for repair.
Any problems contact Lancer labels
Apr 05, 2009 | Zebra LP 2844-Z Thermal Label Printer
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Wont print
Check to make sure you have direct thermal labels. You can test this by scratching your fingernail across the label quickly. You should see a black line. This printer uses the same paper as a ups or fedex label. test a ups of fedex label with the fingernail test. Does it look the same? or call Andrew @ 908-725-1699
Jun 17, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
430 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
