SOURCE: Windows Startup Error csrss.exe
Okay, we are going to try two things. If the first don't work go to the second.
1) First perform a search on your computer for the 'csrss.exe' file. If found, copy it and then paste it into your C:\windows\system32 folder.
That should do it.
2) If that don't do it or your search can't find it, then perform the following;
To scan and verify the versions of all the system files that Windows File Protection protects, use the System File Checker (Sfc.exe) tool together with the /scannow parameter. If the SFC.exe tool detects that such a file was overwritten, the SFC.exe tool retrieves the correct version of the file from the Dllcache folder or from the Windows installation source files, and then replaces the incorrect file.
To run SFC, please follow these steps:
1. Click on Start > Run command prompt
2. Type SFC /scannow, and then press ENTER
Note: You may be asked for inset OS CD.
3. After finishing SFC, you may run CHKDSK C: /R in the Run command prompt as well.
SOURCE: Windows Live messenger Error : 80048820
The problem occurs is caused by the incorrect Microsoft Internet
Explorer SSL settings. The error happens occasionally, and not all system may affected by this WLM problem. To solve the problem, following steps in the guide below:
1. In Internet Explorer, clear the Check for Server certificate
revocation (requires restart) check box. To do this, follow these steps:
SOURCE: windows vista wont start
Ok,Try safe mode with command prompt,If you can get to the command prompt
Type these in one at a time and press enter ( let each one completely finish before typing the next one.)
Bootsect.exe /NT60 c:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
Bootrec.exe /ScanOs
Bootrec.exe /RebuildBcd
bcdedit.exe /import C:\Boot\BCDBackup
If
you are receiving error 80048820 when trying to sign into Windows Live
Messenger you should also get an extended error code. If this extended
error code is 80048412 the problem often occurs because the time and date settings on the computer are incorrect. The error will appear like below:
You cannot sign in to Messenger. Additionally, you may receive the following error message:
We were unable to sign you in to the Messenger at this time. Please try again later.
To let us try and troubleshoot the problem, click the Troubleshoot button.
Error code: 80048820
Extended error code: 80048412
The following steps may help resolve your issue:
To troubleshoot the problem on a Microsoft Windows XP-based computer:
1. Click Start, click Run, type control timedate.cpl, and then click OK.
2. In the Date and Time Properties dialog box, confirm that the date and time settings on the computer are correct, and then click OK.
To troubleshoot the problem on a Windows Vista-based computer:
1. Click Start, type control timedate.cpl in the Start Search box, and then press ENTER.
SOURCE: my modena m101 laptop wont go into safe mode at
hi
1 use bootable cd
2 or emergency windows that installet on cd
3 use repair boot cd (make it with another computer)
