Question about Toro Lawn Mower With Toro Power Tools
It's 6.75HP household Toro Law Mower, It will start but engine won't last for 1 minute and shut off itself. Checked airfiler was very dirty. Gas is full and oil is in normal level. What should we do?
    Genius:
  • 1,341 Answers
Clean the carb,and check flow of fuel to carb,add a fuel filter if possible...You need to do a small servicing on it,a proper one to get it back as normal..Put the carb soaked in thinner overnight and make sure all plastic bits are removed as else it will melt.Also check the valve,just after the carb is it's a 2 stroke( if it has one, as some has not).This should solve this problem and get it back to normal.
Posted on Jul 29, 2009
Lawn mower manuals
because it's a "push" mower... lol, get it... ok let's move on. Dirty air filter and/or spark plug, bad gas, dirty carb, no spark blown engine. operator presence handle not working correctly...
Sep 02, 2014 | Toro Lawn Mower With Toro Power Tools
How do i get my toro gts-5 550 lawn mower to keep running?
The problem is likely varnish buildup in the carb. Add PAINT THINNER ( yes, I meant to say that !) to the gas. Use 1.5 ounces each of Xylol ( Xylel) and Acetone per 10 gallons of gas ( 5 gal. can will use 3/4 ounce each ).Drain gas tank and carb float bowl. Add fresh gas mixed with thinners. Remove air cleaner element and use quick starting fluid with upper cylinder lubricant to start mower, and keep it running with SHORT bursts of starting fluid until it will run on its own. You may also need to replace or clean air filter if it is old or dirty. continue procedure for 5 minutes or so. Remember to run Sta-bil fuel stabilizer through the system before you shut down for the season, as this will prevent the varnish build up.
I've been using thinner in all of my engines ( gas, pre mix, and diesel ) for a few years with no bad side effects. I've ridden over 15,000 miles on my motorcycle - getting better mileage and power, and not having to buy premium gas either.
Hope this helps!!
May 31, 2014 | Toro Lawn Mower With Toro Power Tools
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
MOWER IS HARD TO START
  1. g and wire aSounds like a dirty carb. Drop the bowl ,after shutting off gas, and and with about a2 foot piece of hose, blow up the center tube on the carb.Replace the bowl. Remove the plug and pour about a table spoon of gas in plug hole. Replace plug and plug wire. Try to start it.
Apr 30, 2010 | Toro Lawn Mower With Toro Power Tools
My mower starts and runs until the engine get hot.
the only way to test i think is with a known good coil or resistance check. also possible you need to check valve clearances
Apr 25, 2017 | Toro Lawn Mower With Toro Power Tools
Mower starts then it smokes
If you spilled any oil on the engine, it will smoke for a few good minutes until it burns off.
Or, you may want to check the air breather. It may be dirty.
Jim
Jun 25, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro-recycler. it is about four years old and has always run great-until now..it shut off in the middle of the yard and wont re-start. i put in fresh gas/sea-foam, new plug, and air cleaner..it is...
It sounds as if the gas cap may be clogged. It must be able to breathe so that the carburetor gets the proper gas flow. Does it run for about 10-15 minutes? If so, this is more than likely your problem.
Jim
Toro 2 stroke lawn mower won't start
Remove the Carb Bowl and on the bottom of the bowl clean the center of crust gas....
It blocks the gas from getting from the bowl to the inside of the carb.
Caused when gas dry's up in the bowl leaving deposits behind plugging up the works.
AL
Apr 26, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
