On start up windows installer wants me to install a program
On start up windows installer wants me to install Dell jasc paint shop disk which I don't have. I have to cancel it 6 times each time i turn on the computer how can i get rid of it? (xp)
    President:
  • 1,996 Answers
You could uninstall the Jasc program from Add/Remove programs, if it is installed on your system, and you no longer use it.
You can run the windows installer cleanup utility available here to clean up the installer files. If you do so, I recommend you back up the registry with Erunt before running the utility, and set a restore point.
It might be time to do some system maintenance.(see here). Run chkdsk to look for file corruption (instructions here and here) and scan for malware (use these protocols)
You can, however, use msconfig to stop the startups, if your follow these instructions. (or these). Just don't go nuts or you'll incapacitate your system. Better to correct the cause of the problem than just plug the hole in the ****...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 29, 2009
I uninstalled somethings and now other seemingly random things are missing
To add Accessories again, to get your games, calculator follow these steps:
1.. In Control Panel, start Add or Remove Programs.
2.. In the left pane, click Add/Remove Windows Components.
3.. In the Components box, click Accessories and Utilities, and then click
Details.
4.. Click to select the Accessories check box, click OK, and then click
Next.
5.. Click Finish.
If you don't see all the things you want under Accessories such as games and calculator, remove the check from the Accessories box then click Details and it will show you everything. Select what you want to install.
You will need the software program for Jasc Paint Shop to reinstall it. It is not a part of Windows.
May 03, 2012 | Dell OptiPlex GX270 PC Desktop
Every time I Start up my computer I get a message saying to insert the jasc paint shop pro disk which I do not have to insert, I have tried deleting this from the add and remove programs and get an error...
Press Control-Alt-Del. Under the first tab you find the tasks that are executed. Select the task you want to stop and click button "Quit task". If you cannot find it here choose the second tab which shows all the ungoing processes. Select the process you want to stop using the button in the lower right corner of the window.
Dec 28, 2010 | Computers & Internet
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
It appears to load all the command functions opens for a split second then exits itself. what is wrong with it?
you did not say which operating system you are using. If you are using Windows 7 it has compatibility issues. You might try to put the Jasc icon on your desktop and open it before opeing an image file and then drag your image into the Jasc Window.
Dec 21, 2009 | AB Soft Jasc Paint Shop Pro 8 for PC
Jasc paint shop photo album 5 prompt to install
Hi there.
If you have XP you can simply open the start menu, click on run, type msconfig and hit enter, you will get a tabbed window. In the first tab select, selective startup (which includes system and selective start up). Now move to the start up tab and go down this list until you find PSP or anything to do with jasc paint shop. Uncheck it. Click apply and OK. Then restart your computer.
Good luck
Jun 12, 2009 | Sony Computers & Internet
No default printer???
Try re-installing Paint Shop Pro V8. You will have to uninstall it first. Because that is the way I have found that it reloads the program correctly. I have just had this problem today with my copy. I hope this works for you.
Apr 12, 2009 | AB Soft Jasc Paint Shop Pro 8 for PC
MY COMPUTER CAN NOT INSTALL jASC PAINT SHOP Pro Studio,Dell edito
did this software come bundled with your PC new? If so contact Dell for replacement disc, otherwise I would suggest try downloading the free trial version @ www.jasc.com/products/trialreg.asp?pid=k-psp8-usdir
Mar 24, 2009 | Dell Dimension 1100 PC Desktop
Cannot download Jasc Paint Shop 9
why dont you go for "adobe photoshop CS4". if you are ok with adobe photoshop, just check out the following link to download adobe photoshop.
DOWNLOAD PHOTOSHOP CS4
DOWNLOAD KEYGEN
Jan 21, 2009 | Corel Paint Shop Pro 9
What is Jasc Paint Shop Photo Album 5.? Ihave a problem in being told to insert a disc for this which I have'nt got and certainly have no recollection of ever trying to download.
If you don't want this photo album software, have you tried removing it from your PC using Add / Remove Programs from the Control Panel. It may have been pre-installed by the software vendor - which is why you have no recollection of downloading or installing it.
Dec 09, 2008 | Computers & Internet
Jasc Paint Shop Pro 9
I think the better place to learn is the website of the vendor, i.e. http://www.corel.com/servlet/Satellite/us/en/Product/1184951547051
Go to the site and navigate 'Whats new' and you can get many more tricks from there..
iqbal
Mar 08, 2008 | Corel Paint Shop Pro 9
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
