Question about Canon PowerShot A95 Digital Camera
Pinky distored display
I seem the have exactly the same issues as you have mentioned, although it doesnt seem to ever fix with turning the display on off etc.
I have emailed Canon UK to see if they'll repair/replace my camera.
Have you had any luck getting yours repaired?
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info. And also this link for UK:
http://www.canon.co.uk/Support/Consumer_Products/products/cameras/Digital_Compact/Powershot_A_series/PowerShot_A95.aspx?type=important&faqtcmuri=tcm:14-522149
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Posted on Jul 29, 2009
I use a screen mirror app thru phone norm nd it's perfect but doesnt seem to work anymore. It had a few secs delay in showing on TV then the screen goes crazy & green.Now it won't connect HELP!
It's always helpful to mention what kind of phone you have and what the app is you're using, but my suggestion is to delete the app from your phone (if it is one you downloaded), turn the phone off and then turn it back on, and redownload the app. Hopefully this fixes the issue!
Sep 26, 2016 | Cell Phones
Hello, I have an issue with a SONY KLV-40BX400, the TV turns on, displays the sony logo and plays the power on sound then turns off and turns on a few times and then doesnt turn at all and
If it is PLASMA TV.....
brandon barnes mentions..there is usually nothing physically wrong with 6 blink tvs..you need to reset the TV using the original remote
Not sure if the fix mentioned below is appropriate for your TV Sony eSupport Electronics Drivers Software
Aug 03, 2016 | Sony Televison & Video
Fan always runs, speed doesnt change (low/high), setting humidity level doesnt impact...is this a control board or circuit board issue?
Verify the humidity reading with another device. Perhaps the humidity sensor is dirty or bad.
Another possibility is the switching device that runs the compressor and fan is shorted. If it's a mechanical relay, the contacts may have welded together, or if it's a solid-state relay, it's got a punch-through or meltdown in a device junction. My guess is it's a mechanical relay since you mention it used to click on and off and now you don't hear that. The relay may be on the control board, or it may be mounted separately - I don't have a photo or diagram of the inside of your model available.
Jun 25, 2015 | Dehumidifiers
Although no paper seems stuck in the printer the display keeps repeating paper blocked
Although you didn't mention what type of printer, most of the time that I have seen this error it has been a paper issue. It can be the tiniest of pieces of paper that has torn off and gotten stuck somewhere inside the printer. It can also be a small piece of a label if you use the sticky labels in your printer.
If you have done everything to clear the paper path, opened the doors, and pulled out the trays, you may want to try spraying some canned air into the printer to see if anything comes loose. The only other way I have been able to fix this issue is to tear apart the printer and find the tiny piece of paper.
Jan 20, 2011 | Computers & Internet
Turns on fan runs but no info to the monitor doesnt seem to boot
If the Monitor is displaying no infomation at all, your display signal from the PC to the monitor has failed.
1: Check the cable between the monitor and PC
2: If you are using onboard graphics then that display port is faulty.
3: If you are using a graphics card then remove it and try the onboard graphics.
4: Your monitor maybe faulty aswell so test it on another computer to be safe.
Its more likely to be option 2
Jan 15, 2010 | Gateway GT5220 PC Desktop
The color on my wesinghouse is distored everything looks green HELP
Have you tried a full removal of the AC power. If you have and it still is doing this. Try a differnt source such as a DVD or VHS input. It would be good if you had one of these connected to see if it's image is also green.
Note: what color are the TV's menus when they display.
Normal or green also.
If they are normal then it's a processing board issue. If the menus are green also then it's a LCD panel issue. Both aren't cheep to fix.
Blessing,
A/V Media Guy
Nov 20, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Distorted picture. changes from color to black and white.
Hi, this is a bad main board that is causing this issue you are experiencing. simply replacing this board will fix this issue.
Click Here
May 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Acer Aspire 4520 display off suddenly without warning
please clarify this sequence of events: "on AC power,it seems to be working fine. But the problem occurs when I try restart it on the next morning"... was it restarted next morning on AC power or battery...which one?
Aug 26, 2007 | Acer Aspire 5100-5033 Notebook
Speedlight SB-600 Display flashing.
My SB 600 is doing the exact same thing. I used Nikon's online support service and this is the response I got: "I would try doing the 2 button reset on the flash and then see if that helps. Also disconnect any battery packs you may have connected especially if its a third party battery pack. If none of the above work then please service the speedlight" Sounds like they don't know what it is, either. I tried the reset to no avail. I'm not sure I want to send it in to have it fixed, since it does seem to be working. But you're right, it's annoying.
May 17, 2007 | Nikon Speedlight SB-600 TTL Flash
Canon PowerShot A95 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
