SOURCE: LEXMARK X5270
tried to install lexmark x5270 printer without the CD with no luck. need help rb
SOURCE: Lexmark x3480 cartrige incorrect message
I had the same problem. Downloading and running the patch program solved it for me. Follow the link below!
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:570:0:0&docid=ENUS25374
Regards Robin
SOURCE: error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
SOURCE: Lexmark X3550 ink cartridge #23 receiving error
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue.
The upgrade for the X3430 is available from Lexmark at:
To install the firmware upgrade,
When the update finishes the printer will restart and will accept the cartridges. Please contact Lexmark support if this does not fix the problem.
A similar patch is available for the X3430 and Z1420 models. See http://bit.ly/LoXxv
SOURCE: left ink cartridge incorrect
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue. The upgrade for the X3430 is available from Lexmark at:
This works for the X3550 and X4550 models. A similar patch is available for the X3430 and Z1420 models. See http://bit.ly/LoXxv
