Question about Zenith H20H52DT TV
Tuner is out. Menu works, but TV has a snowy picture.
  • 1 more comment
  • stolley Jul 30, 2009
    I am on a cable TV signal. The TV has a snowy picture. I can get the menu and channel numbers, but no stations. This is the 3rd or 4th TV to do this. I am looking for a common problem. Bad solder joints, maybe.
  • Adnan Bhatti
    Adnan Bhatti May 11, 2010
    Do you have a terrestrial antenna or cable subscription?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
MY SAMSUNG LCD TV MODEL LNS4695DX HAS A SNOWY PICTURE CAN SEE PICTURE BUT IS VERY SNOWY I TRIED ALL INPUTS WITH CABLE DVD AND A GAME SYSTEM BUT NOTHING CHANGES AND THE WIERD PART IS WHEN I HIT THE MENU...
The OSD comes from a different area---if on all inputs it is on a board that processes all signal in the set--tuner,AV etc
You might want to Google the model number with "parts" to come up with a list of the boards and prices if possible for them.
Dec 04, 2012 | Toshiba Televison & Video
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
No picture
I can suggest unplugging the TV and leaving it off over night. This will do a power reset and may correct the problem. If not the only way to determine the problem with the TV is testing the circuits. For a simple repair you can expect to pay in the ballpark of $100 for the repair.
Hope that helps.....
Aug 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
I am having onida 21 ky thunder 800 tv.i am not getting clear picture is there any secret menu settings which can help me
You must apply a clean signal and see that the picture is clean if not the TV tuner section is faulty.
If there is snowy picture then the input RF section , the TUNER section and the VIF/SIF section must be checked.
There is not much in the menu than to use a fine tuning to have a clean picture.Otherwise the tuner is a suspect.
Sep 02, 2011 | Televison & Video
Misubishi warrior 2 intermitant pic freezes 1 second or less
Hello frogman,
The freezing of the picture denotes a loss of signal on a digital (Having a ATSC tuner) TV. If your TV is not digital (Having a ATSC tuner) then it is the device that you have connected to the TV (Cable Set-top Box, DTV Tuner, etc). In the likelihood that it is your TV I would suggest getting a better antenna first if that does not fix the problem you may have a tuner problem. However lets not look at it that way first. What we need to do is to determine if it is the TV of whatever you have connected to the TV.
First unhook the connection you have from the cable to your F connector of the TV (you should see snow or a blank screen) connect a antenna to the F connector of the TV, do you see a snowy picture or a clear sharp picture (snowy= NTSC tuner, clear-sharp= ATSC tuner). If the tuner is NTSC then check you cable device and the connection between your TV and the device and the cabling between the device and the wall. If the Tuner is ATSC then you will have to check all of your connections, and finally if the tuner is bad it has to be replaced by a qualified Tv repair shop.
I hope this helps,
Thank you,
Shuttle83
May 09, 2008 | Televison & Video
Picture clear then fades to snow when it does, makes annoying sound
sounds like poor solder on the ground conections of the tuner, depending on the age of the TV frostman
Feb 11, 2008 | Sony KV-27FS13 27" TV
Akai PDP4294 - Snowy, pink & green picture
It is most likely a problem with the tuner, I would contact the place you purchased it or your nearest repair shop.
Feb 07, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Hitachi snowy screen and noisy
you have broken solder connections inside the tuner, you`ll need a tech as it is soldered in and once removed the board inside will have to be re-soldered. An alternative would be to use the AV outputs of your cable box or vcr to the AV input of your tv, this bypasses the tuner circuit, you will of course have to go into the tv`s menu and switch to AV 1 or AV 2 whichever input you use, good luck& Happy Holidays
Nov 29, 2007 | Televison & Video
Picture is snowy on every channel. I hooked up my playstation and set it to the correct channel but the screen display is the same. I tried using the menu and the menu comes up just fine. The menu goes on...
If one tv looks good and another one dosent look good or operate correctly then we know for sure that the problem is not the antenna. Now the menu comes up ok because the menu is injected after the tuner into the video curcuit from a osd or microprocessor. sounds like you could have a defective tuner or antenna block assy.
Mar 27, 2006 | Toshiba 42H83 42" Rear Projection...
Zenith H20H52DT TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
