Question about Sharp Office Equipment & Supplies
Will not power on
Sharp AL-1000 copier went from operating to not powering up when turned on. No lights or any response whatsoever. Outlet has power . Is switch defective?
    Scholar:
  • 136 Answers
Their's three possible solutions either the switch is defective , you have a Blown Fuse on your Power Board, or your power supply is bad.
Posted on Aug 04, 2009
Sharp AL-1041 Printer/ Copier will not power on
make sure you are not plugged in to an outlet controlled by a wall switch. Bypass any power strips.
Aug 07, 2012 | Sharp AL-1041 Laser Printer
My Sharp AL 1000 is displaying alternatively the letter H and the number 4. What should I do?
Hello
The error that is on your disply is the following.
The fusing temperature does not reach 175 degrees celsius within 30 seconds of turning on the power, or the fusing temperature keeps at 140 degrees celsius.
In sequence press the following buttons [clear]-[density select]-[clear]-[desity select] the display will go blank.
With the copy quantity keys input 14 and press the start/print button, the machine will cycle.
If the error returns then the thermistor and themo fuse will have to be rplaced.
I hope this helps you
Regards
Apr 16, 2011 | Sharp AL-1000 Copier
Sharp AL-1000 error E7
E7 is CCD drive circuit trouble. Refer to the manual
obtainable from mauritron
Feb 21, 2011 | Sharp AL-1000 Copier
Last button on Sharp AL-1000 keeps blinking will not copy.
It most likely is out of toner. Does it run and run and run when you turn it on ? It should " warm up " in a minute or less. If so, the toner is empty
Oct 28, 2010 | Sharp AL-1000 Copier
MY SHARP AL-1000 PRINTER IS PRINTNG VERY FEINT
Could be either one. Probably toner.
Apr 06, 2010 | Sharp AL-1000 Copier
I HAVE A SHARP AL 1641 CS COPIER AND THE DRUM I WAS GIVEN WAS SHARP AL 1000 DRUM UNIT AL 100 PART MS1DR AND THE DRUM LIGHT IS STILL ON AND THE COPIER WON'T WORK, DO I HAVE THE RIGHT DRUM AND IS THERE...
The AL1000 drum unit is the same as the AL1641 drum.
I do not recognize the MS1DR as a sharp part number.
You can reset the drum indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
This should make the copier operational again if all you have is the drum light.
Dec 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Repairs of sharp AL 1000
Sounds like the scanner is locked. Look under the scanner where the paper comes out, there is a clear wheel, turn it all the way one way or the other and that will unlock the scanner.
Oct 21, 2009 | Sharp AL-1000 Copier
Sharp al 1000 shows E and 7 and hangs off
if a number and alphabeth appears alternately The copier will not function. Turn the power
switch off, remove the power cord from the
outlet, contact any authorized service
representative for overall service maintainance
May 18, 2008 | Sharp AL-1000 Laser Printer
49 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
