Question about Ecg Medical
Hello Sir My Kenz ECG machine Model Cardico 302 is printing Blank its after we just cleaned the thermal head .What may be the solution for that problem.
    Habit-Forming:
    Scholar:
  • 69 Answers
Check for a loose connection on the print stylus. These are very delicate and break easily. Like any thermal stylus, it is only a heater which is very brittle and cracks easily. If you have a volt meter, see if you are getting voltage to the stylus but I believe it was accidentally broken while cleaning, happens all the time.
Posted on Dec 20, 2017
SOURCE: Thermal print head repair
I have an Evolis Pebble 4 Printer. We use this machine to Print at leat 2000 cards a day.
We would like to know from where OEM Printheads for this machine can be procured as the
cost of the originals is too hgh?
Posted on Nov 13, 2008
SOURCE: Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
Posted on Nov 21, 2008
  • 71 Answers
SOURCE: GE MAC 5000 with a printer problem
You are probally using the wrong paper. Look at the part number for the paper you are using and cross refrence that with the correct number.
Posted on Jun 03, 2009
  • 16 Answers
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Posted on Jul 22, 2009
AJIN G
  • 6694 Answers
SOURCE: How does ECG machine find
hi,
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have already memorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
Posted on Feb 06, 2011
The Ecg prints at some parts of the paper but some parts are not clearly printed,what's the problem?
The thermal printer head is faulty.nyou have to replace the thermal printer.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
Feb 05, 2016 | Ecg Medical
My cardiovit AT-2 PRINTS ONLY ON ONE CORNER ..... CLEANED IT ....
have problem with the thermal printer head. It need to be replaced. You have to contact the Schiller authorized serving center to get it repaired .
Here i have have added the part description and part number.
Part description
Thermal, Print Head Springs (2-required)
Part number
85295-0000
Electronics Equipment Repair Center
Dec 30, 2014 | Medical
New Contec ECG 300EG model no tracings appear on the EKG paper.
Ekg machines print on thermal paper, This means that the impression is made by the print head heating the paper. If the print head is not making contact with the paper, you will get a faint tracing or no tracing at all. This needs to be adjust by a technician. Contec is located in China and we are a dealer. If you need their info or want us to look at it for you (for free) simply give us a call
Discount Cardiology
805-484-9985
Aug 18, 2012 | Contec Medical
At-2 lite model not printing visibly patient data and interpretation also have blurred upper part of EKG print. All leads are printed well. Is this setup problem or malfunction?
hi,
check the paper you have inserted. if the paper quality is bad then the printing can become bad. Use schiller original paper.
if again printing is bad then the thermal printing head of you machine is faulty or the. you have to replace the same.
ok
Apr 10, 2011 | Schiller Cardiovit At 2 Light Ecg Machine
The ECG machine expels the paper but with no ecg record on it, please advise?
hi,
Your machines thermal printing head have some problem. Thats why it doesn't print any thing on the paper. Not possible to repair thermal head. You have to replace it with a new one..
ok
Feb 17, 2011 | Schiller Welch Allyn Cardiovit At 2...
High, I have a Schiller AT-2 light that is printing too lightly suddenly. Hard to read the lower page tracing in particular. Had it 5 years, doing well. Anything to adjust that?
hi,
Your machines thermal printing head have some problem. Thats why it give printouts very light. Not possible to repair thermal head. You have to replace it.
ok
Feb 15, 2011 | Schiller Cardiovit At 2 Light Ecg Machine
There is no printing
hi,
may be ur machines thermal printer head have some problem. also check the paper u have inserted. it should be a wax paper or chemical paper.
ok
Dec 24, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
My machine needs the ink changed? how do I do this
There is no ink in that model, it is a thermal printer. You might have the wrong paper or a bad print head or a bad print roller. To test this. Get some thermal paper (You will know it is thermal if you expose it to a heat source and it turns black) and some electrical tape. But a small strip of electrical tape on the print roller. Then do a test sheet. if it prints out darker where you have the electrical tape on the roller it means you need a new roller or possibly a new paper tray cover. You are not getting enough pressure where the two make contact. if you get nothing you need a new print head. We can help with this, 800 989 4909, ask for Jeff
Oct 15, 2009 | Schiller Cardiovit At 1 Ecg Machine
Hello LV792727, Disconnect the AC & battery power and proceed with caution. Open the case to aquire access to the thermal print head. Clean the print head with a white eraser, the type used for cleaning ink prints not the #2 pencile eraser. Test the printing function. If necessariy use a Q-Tip with a light touch of Aceatone to whip the print head. The next step is replacing the printing element. Please inform me of the results. Good luck.
Oct 22, 2008 | Schiller Welch Allyn Cardiovit At 2...
Solid Blank Line
If it's blank, is this on what you send/recieve?
Also if you print something like a status sheet, is it missing on those too? If so, your print head needs replacing.
If its on copies/sents you need to clean the scanner head.
Feb 15, 2008 | Brother IntelliFAX 885MC Plain Paper...
Medical Logo
120 people viewed this question
Top Ecg Medical Experts
ray gallant
Electro Med Services...
Are you an Ecg Medical Expert? Answer questions, earn points and help others
