Question about Kenmore 24032\24036 Top Load Washer
Clicking noise. BUT DRAINS FINE!
My Kenmore 80 series top-load washer clicks instead of spinning, but the pump is working fine. Flipped it over and belt is loose and up around a black shroud. I'm thinking it should be lower on the stainless torque converter. Any ideas?
    Genius:
  • 1,122 Answers
Kenore don't have belts they have couplers,check the lid switch-mike
Posted on Jul 29, 2009
Kenmore Series 80 Washer Drips and Spin Cycle Sometimes Has Low Torque
Does it leak every time it's run, or only occasionally? It could be that the belt on the drain pump is going bad or is loose, so it works some times but not always. Could be that the belt broke or the drain failed, so it will always leak from now on. It's hard to say without actually taking it apart and having a look
Dec 31, 2012 | Kenmore Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Does 80 series have a belt to make drum work it will not wash or spin just makes a noise
No belt, they are a direct drive and use a motor coupler instead. They coupler doesn't cost any more than a belt did, and is pretty easy to replace.
Dec 30, 2009 | Kenmore 24902 Top Load Washer
My kenmore 80 series washer will not agitate or spin, water flow in and pumps out fine
it is a drive problem consisting of several things.. bad motor, drive belt slipped off, clutch froze up, drum brake engaged, or no power to the motor. have it checked by a professional.. good luck
Nov 15, 2009 | Kenmore 24032\24036 Top Load Washer
There appears to be a thin rubber belt out of place on the bottom of my kenmore 80 series washing machine. what is this?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If everything is working correctly, the belt / band that you see is a snubber or vibration damper that fits around the brake housing.
It won't hurt the washer if it's not on the housing.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series spins but won't ring out clothes
Check for buildup of detergent/foaming while washing. Check for oil leaks around the clutch area. Could also be the clutch lining is worn out. Replacement parts kit includes all parts
Mar 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series makes noise in sping cycle
Its the transmission. Try to find a used appliance store in your town. Most save used parts and you should be able to pick up a used tranny for around 100 bucks.
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
136 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
