Question about Saeco Vienna De Luxe Espresso Machine
Vienna deluxe can't get dump box back in - brew group flap in the way
I have removed the dump box and now i can't get it back in or the brew group out. there is a flap from the brew group that is too low. please advise.
  • Saeco Expert
  • 223 Answers
Leave the dump box out. Use a spoon to hit the switch where the dump box would normally hit. Hold the switch until the flap is no longer in the way then replace the dump box.
Espresso Machine Service
Posted on Nov 24, 2007
Saeco Vienna superautomatica won't dump grounds puck into dump box
This needs looking at by a Saeco repair shop - the brew unit travels in a distinct 'pathway' from being empty, to filled, to coffee being tamped, then to being emptied. Yours is obviously not working as intended.
It may be the brew unit needs lubricating ( NOT OIL) or it may be the gear system that drives the brew units movements that needs attention.
Nov 14, 2017 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna. Wet cofffee grinds in the dump box.
It could be the grind on the coffee or the red group o-ring and the 2 o-rings on the white plastic valve need to be replaced.
Nov 05, 2009 | Saeco Vienna De Luxe Espresso Machine
The brew group to my Vienna Deluxe is out of sync. I cannot get it to fit into the machine and then add the dump box for the grains. They do not fit. I do not want to force the brew group into place....
Problem: Brew group is out of sync. Brew group insertion. Brew group alignment.
Answer: Common to all Saeco superautomatics. After removing and cleaning the brew group, it will get onto the supports but will not lock into place as the gear is not aligned. With the brew group on a clean, well lit table, use a pair of chopsticks and a friend to assist. There is a small lever arm on each side that is accessible from the outside of the brew group. As the carriage slides down towards the correct position, the arms are seen 1" above the drive gear and towards the handle side of the brew group. Gently push in the lever so it slides inside of the locking bar. Both sides need to get pushed in at the same time so it helps to have a friend hold the brew group and push in one side while you pull down on the carriage and push in the other lever. The chopsticks insert into the half-moon on each side above the locking mechanism.
Jul 31, 2009 | Coffee Makers & Espresso Machines
Low water pressure
i had the same problem the brew unit was block from many shot remove the little tube on top of brew unit be carefull after removing the 2 screw there a spring under the tube and glass ball clean it good
Apr 09, 2009 | Saeco Vienna Deluxe
Saeco Vienna deluxe brew group was jammed
If you have the box the machine came in there is a key that kinda looks like a wine opener, use that to set the little arrow on the brew unit to the "N" letter, then the unit will fit into the machine.
Dec 26, 2008 | Saeco Vienna Digital Coffee Maker,...
Brew group/dump box
If you open the door, start the machine, take a screwdriver in the hole lokated in the left lower side and a other in the hole lokated in the right top corner. Now should the machine do her selftest and go back to start positions.
Jul 07, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Dump box and brew group stuck
sounds like you inserted the brew group wrong.
if stuck it can be sometimes a hassle to get it out.
ok try these options.
Turn on ,off and on again see if that straightens the brew group out. If not open the door and try to push the knob of the brew group, push it inward and than pull it out . Make sure you try it first with power off. If this does not work pull on the moment you power the machine on.
Let me know what happens. We'll fix it
Apr 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Water in dump box
You have more than one problem.
You need to order a new filter since, if it is stripped, you cannot use it. The water in the dump box is caused either by that filter not being clean and not allowing the water to pass, thus dumping it into your dump box(the usual case), or a worn or failed O ring.
The other problem, the brew group not working, could be caused by any number of issues and would need more information. You may simply have not put it back on properly or got the timing sequence off.
Mar 14, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
420 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
