Question about Neff U1461 Double circotherm plus Electric Oven
Light on fan on no heat - Neff U1461 Double circotherm plus Electric Oven
  • Neff Master
  • 3,463 Answers
Hi.
You need to fit a new oven element, as this is the reason you are getting no heat.
Please rate my solution.
Thanks.
Posted on Jul 29, 2009
No lights on oven, fan working no heat
No heat and fan working usually means the heating element has failed. Before you go down that road get the oven light checked as well in case there is a central problem. If by no oven light you mean the internal oven light is not on then that is just a bulb replacement. Make sure you get a heat resistant or original spec one though.
Jun 02, 2015 | Ovens
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Bosch double oven, fan and light work but won't heat.
my lower oven wont heat on my HBN 70 got light and fan but no heat
Oct 18, 2009 | Bosch Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Jul 28, 2009 | Ovens
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Elan 948 OVen doesn't heat and light designating heating does not go on.
we just had the same problem with the same oven. pull the oven out of the wall. on the top right side there is a fan. there is a safety switch that is activated by the fan blowing on it. a piece of insulation was preventing the switch from activating so the oven thought the fan was not running. remove the insulation and the oven comes back to life.
Oct 22, 2007 | Elan E-948-CB / E-948-CW Oven
Neff U1461 Double circotherm plus Electric Oven Logo
147 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
