Computers & Internet Logo
J
James Yaeger Posted on Nov 20, 2017
Sound good during diagnostic test but no sound on normal operation. Sound ok on 2nd samsung using same wifi.???
5 Related Answers
Anonymous
  • 128 Answers
  • Posted on Jan 18, 2008
SOURCE: Bosch SHU9915uc/u12 making noise
Try out this site. Hope this helps :)
http://servicefunctions.bosch.com/user/contactdealer/index.asp?country=wo&lang=en&app=contact&gb=&option1=&option2=&option3=&email=&opener=http%3A//www.bosch.com/content/language2/html/index.htm%23%23%23
A
Anonymous
  • Posted on Aug 11, 2008
SOURCE: samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
Anonymous
  • 7752 Answers
  • Posted on Oct 25, 2008
SOURCE: Samsung D900 no sound. sound
the speaker and ear piece need to be fix or replaced
Anonymous
  • 4234 Answers
  • Posted on Dec 04, 2008
SOURCE: Technics SA-DX950 has lost digital sound
This may sound like a silly check, but verify that the tape monitor switch is not engaged. What is the quality of the sound when turned up? Is the cound clear or raspy?
Thanks,
Dan
Anonymous
  • Posted on Apr 05, 2009
SOURCE: My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Samsung UN55J6200AFXZA. Lost picture and sound. Fuse on power board OK. Replaced power board and it did not solve my problem. Did flashlight test and I can see an image on the screen.
Samsung has self diagnostic software built into the setup section on your settings. There you can test sound, display and more. Give it a try, maybe that's where your answer is. It solved my sound problem. also check to see if it has a back light, like a monitor or laptop screen would have. If its bad you could replace it. Have fun.
Lynn
2answers
My hp office jet all in one printer is only displaying error ,when i turn it on
HP Officejet J4580 All-in-One Printer Troubleshooting ' HP ...
support.hp.com/us.../HP-Officejet...All-in-One-Printer.../troubleshooting/
Let HP find my products ... Note: This tool can only find HP products you are currently using or ... Error · Printer Problems after Upgrading to Windows 10 · A 'Paper Jam' Message Displays for HP Officejet J4500/J4600 All-in-One Printer Series ... PrinterSpecifications for HP Officejet J4500 and J4600 All-in-One Printer Series ...
A 'Paper Jam' Error Displays on the HP Officejet 4215 a
Black cartridge problem device documentation. HP Officejet 4500
This type of HP 901 ink cartridge error ("Refer to Device Documentation", etc.) condition is likely an internal micro-electronic failure inside the HP 901 (or 901XL) black ink cartridge. These failures typically occur due to natural degradation of internal micro-electronics over time and can occur with brand new ink cartridges.
To confirm root cause and check the internal electrical condition of both black and color ink cartridges, please execute the 'Tap 41' cartridge's electrical diagnostic test below (refer to procedure B).
CAUTION: Be advised, the use of remanufactured ink cartridges is considered somewhat unreliable since the cartridges are already on their 3rd life when purchased new (off the internet or at select retailer stores). As well, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors.
NOTE 1: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC CHECKS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to 2nd video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=620
a. Load Letter/A4-size paper into paper feed tray.
b. If any lights are blinking, first press Cancel to attempt to clear.
c. Press the * and # keys simultaneously.
d. Enter 124 at keypad. The 'Underware' menu should be displayed.
e. Use the arrow keys to navigate to the System Menu. Select Ok.
f. Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Printer screen should display "code = 0".
g. Use the arrow keys to enter "code = 41" (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern prints.
--- Providing the HP 901 (or 901XL) color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health - the printer will attempt to print the diagnostic test print). A good HP 901 color cartridge should display 1248 good nozzles, while a good HP 901/901XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the diagnostic test print: http://inkjet411.com/?page_id=620
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For more diagnostic tests and error bypass procedures, please visit the Inkjet411 support center: http://www.inkjet411.com
Hopefully this helps....
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and...
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
10helpful
Error code 88 88
The 88 88 code indicates a modem communication error in the refrigerator. This error is not applicable in the U.S. It should be ignored. The control will conduct a self diagnostic check when it is powered up. When this code is encountered it will just need to be cleared and the refrigerator will resume normal operation. To clear the code, press and hold the POWER FREEZE and POWER COOL buttons simultaneously. NOTE: Be sure to press these two buttons at EXACTLY the same time -- no sound will be heard when the buttons are both pressed properly). HOLD the buttons down for about 8 to 12 deliberate seconds until the control beeps and goes blank. Leave the control in this diagnostic test mode and allow it to exit after it times out in that mode. This will take several minutes. When the test mode clears the fault code 88 88 and returns to normal operation, you should be able to set the controls on the unit and it will work normally.
Frank V.
2helpful
3answers
My Samsung refrigerator makes a funny whooshing sound.
Try removing the ice tray and look for cubes jammed between the ice maker and the wall. After I cleared them out the whooshing stopped immediately.
2answers
Please, help me find the sound and WiFi drivers for laptop NEC LaVie LL900 (made in Japan). Thank You in advance!
Normally I'd recommend that you download the appropriate drivers directly from the manufacturer's website but I found the NEC site to be absolutely rubbish for support. I'm guessing that the majority of parts they've used are manufactured by other companies to save on costs and NEC don't want to advertise that fact. Hard for me to recommend anything further without knowing which operating system (Vista?) you're running. This site has supposedly got the sound card driver: http://tinyurl.com/3a7ddgg
2answers
2answers
Noise inside cabinet
FIRSTLY if you have warrenty use it if not use the following steps .Open up your computer DONT TOUCH ANYTHING INSIDE , discharge yourself by touching an unpainted surface then proceed, turn on the pc Sound can vary one way that you can determine the source of noise is stoppping the fans whilst it is on one by one to determine the source.you can remove the cd /dvd from any optical drive (dvd cd drive) .And 2nd you could tell if the hard drive is crashing if you hear a reoccuring clicking sound or a whirr of which the hard drive is crashing.Depending on your manufacturer of hard drive download their hard drive diagnostics program and check for bad sectors if there is an increasing number of it occuring then your hard drive would definately be in trouble.Any sign of this vibration can be caused by vibration so try to keep all the screws tightened .
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
