Question about HP Compaq 6720s PC Notebook
Toshiba won't find wireless router
My computer won't find the alltell wireless router. The problem they say is the network adapter . I have Vista on my laptop.
SOURCE: INTERNET TROUBLES WITH ATHEROS AR5005G WIRELESS NETWORK ADAPTER
how do you do that?
Posted on Mar 31, 2008
  • 12 Answers
SOURCE: Cannot connect 2nd laptop to wireless internet.
go to your acer and go to net work then net work again and in the tabs above choose add device to net work click on that and put a usb flash drive in and download to flash drive and put the drive in hp and it should automatically run the set up and start to work
Posted on Jan 22, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: My HP pavilion laptop dv2000 has worked fine for
Go to your device manager and make sure that you still have a network adapter and that something did not kick it out.
Posted on Feb 18, 2009
vincent721
  • 240 Answers
SOURCE: Wireless connectivity with Vista
since you have verizon modem wireles router..
i have the same issue with the same model...I call verizon and tell the issue...verizon accepted that modem router have problem in wireless...i know that all my computers have no issues because i maintain and built those computer by me..
then Verizon send a new and different modem router...this time it works fine...since i received it last week. call Verizon regarding the wireless issues ..tell them too that you have some dead spot on your wireless..like if you move away more than 15 feet..your wireless connection get lost..
i hope this might help
Posted on Mar 16, 2009
  • 226 Answers
SOURCE: i can not load the wireless network adapter drivers
try to uninstall the drivers for the network adapter and reinstall them
or
First lets confirm your issue. Right click on “Computer” or “My Computer” in XP. Select Manage and then on the right side select device manager. On the left if you see a yellow exclamation mark next to your drive and were getting any of the above error codes then we have a simple fix.
Go ahead and right click on the CD or DVD drive that has a yellow exclamation mark next to it and select delete or remove.
For Vista click the windows “start” button on the bottom left and in the search box type regedit . You will be asked to confirm your admin account. Just hit next or continue.
Now browse to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
It’s just like browsing through folders so don’t worry about it. if you get lost just start over. BE SURE you follow the path 100% There are many similar files and folders so double check they all match up.
Now that you are at the {4D36E965-E325-11CE-BFC1-08002BE10318} Folder on the right side you will see several entries. right Click and delete the Upperfilters and Lowerfilters. These will be remade once you reboot.
for XP follow the above but instead click the windows start button and then select run then type regedit .
Reboot your computer once you have removed the upper and lower fillters. When your computer boots back up it will see the drives as new devices. give it another 20-30 seconds to install the new device.
Posted on Jul 20, 2009
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
Nov 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Just got a new linksys e3000 router. all other laptops working fine except one toshiba with vista. i have another toshiba with vista that is working fine also though. it will connect wirlessly if i disable...
You have to update the wireless adapter driver on the toshiba website. I'm guessing you have an Atheros adapter because those usually have this problem. The driver is not advanced enough to log onto a WPA or WPA2 encryption, WEP will work fine. The driver updates have a 50/50 chance of fixing the problem otherwise you are stuck with WEP.
Jan 11, 2011 | Linksys E3000 Wireless Router
I have a new toshiba laptop that I can't get to connect w/o wires to my lynksys...how do I get my laptop to be wireless??
In order for the wireless computer to connect to the router wirelessly, the router and the computer's wireless settings should be the same. Before trying to connect your wireless adapter to a Linksys wireless router, please know the following: SSID or Network Name, Wireless Security and/or Network Key.
Connecting to Wireless Networks Using XP's Wireless Zero Configuration
To connect to the wireless network using Windows Vista, click here.
Follow these steps to connect to your wireless network using XP's Wireless Zero Configuration.
Step 1: Right-click the Wireless Network Connection icon at the bottom-right of the screen and select View Available Wireless Networks.
NOTE: If Wireless Zero Configuration (WZC) is disabled or other wireless network monitor is running, the Wireless Network Connection will not appear at the bottom-right corner. To enable WZC on the computer, contact Microsoft or consult the computer manufacturer.
Step 2:
Select your wireless network
Nov 05, 2010 | Computers & Internet
We have a new laptop, and desktop and a linksys
by default all laptop has wilreless adapter inbuilt in it
but desktop doesnot have wireless adapter
if you have wireless adapter on all laptop and desktop
in that case
reconfigure wireless setting of router
changed ssid and network key
regards
prakash
Mar 14, 2010 | Linksys Computers & Internet
2wire312
You may want to double-check if the wireless adapter on your laptop is enabled. If it is enabled, try to view the available wireless networks on your wireless connection and select the name of your wireless network. You may also want to check your wireless router if there is a wireless security enabled. It is important that you know the wireless settings on your wireless router to make sure that the wireless adapater settings on your laptop match the settings on the wireless router.
Jul 02, 2009 | 2wire HomePortal® 1800HW Router...
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
D-Link 615 stopped connecting with wireless
If your laptop is not detecting the wireless router, can you try to get the laptop closer to the router ? If you have done that already, I would suggest you to try and power cycle the router once. If that doesnt work either, try to reset the router. Hope this helps
Thanks Ranjit ranjit@supportminds.com
Jun 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I can connect to my router but not to the internet ?
Check if you are able to go online wired through the router. If not then you will have to configure the router. If yes, then disable any firewall on the concerned computer using wireless adapter and reconnect to the wireless network. You may also have to assign static IP and DNS if required. I can bet you have windows VIsta on this computer.
Common problem for Vista.
Rate it,if it helps.
Jun 05, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Remote pc cannot access wireless
You can do a reset on your router. All computers must be must be getting its connection from your router. Your wired computer must be getting an ip address from the router(example is 192.168.1.x). You can then access the router page using your browser by typing the default gateway(example 192.168.x.1). This will take you to the router configuration page. You can set up the wireless network and your wireless network can now support more than 2 wireless computers.
Mar 14, 2008 | Computers & Internet
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
HP Compaq 6720s  PC Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
