Exercise & Fitness Logo
K
Kim Lewis Posted on Nov 20, 2017
I have a Weslo Cadence 927 Spacesaver treadmill but cannot use it because I no longer have the key for it and it will not start. Is it possible to purchase another key?
5 Related Answers
joboo1
Jim London
  • 257 Answers
  • Posted on Mar 14, 2009
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Anonymous
  • Posted on Sep 03, 2009
SOURCE: lost key for my weslo cadence 860
We found the key.
Thanx
Anonymous
  • 103 Answers
  • Posted on Nov 25, 2009
SOURCE: I was given a Weslo cadence 825 treadmill. I need
go to iconservice.com they have free manuals and also you may purchase replacement parts there as well. Be sure to get your model number before going to the site to make it easier (lower frame of the machine)
Good luck, Tim
Anonymous
  • Posted on Mar 23, 2010
SOURCE: i have a weslo cadence 845 treadmill and i lost the key.
use a magnet
Anonymous
  • 34 Answers
  • Posted on May 24, 2010
SOURCE: I have a weslo cadence 200 cs treadmill. I changed...
You probably need a new treadmill display screen but one thing you can try is to get a 6 volt power suppply and use the power supply instead of the batteries.
1helpful
My belt is slipping to one side and i no longer hav the manuel
hi
chek if it is level
and then turn rear roller bolt of treadmill to clockwise you should turn the side which is closer to the to the foot railing(i mean slipping to the side)
1 step
check if treadmill is level
2 put tread work on speed of 2-3 mph
3 turn rear roller bolt of slipping side 1/4 clockwise with small steps and you should see it going to center
5helpful
Lost my weslo cadence 805 manual. Need to download one
You can go to iconservice.com to download your manual. When you get there just fill in the model and you will be able to download the manual.
Hope this is what you were looking for.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
I have lost my manul for the cadence 927 model treadmill
hi, the people you want to speak with are ICON HEALTH & FITNESS
these are the main suppliers of weslo treadmills their telephone 08451770512
based in leeds west yorkshire. i am sure they will e-mail you a manul. i have the m6 and i got my instruction booklet from here!
4helpful
Is the Welso Cadence 927 Treadmill in miles or Km?
hi, the console can display speed and distance in either kilometers or miles!
step 1/ move the key and hold down the stop button.
step2/ reinsert the key into the console, after you hear a bleep tone release the stop button and an "m" for kilometers or an "e" for english miles will appear in the display. press the speed in-crease button to change the unit of measurement.
step 3/ when you have chosen the miles take the key off and reinsert it. hopefully you should have changed your units to whatever you have chosen.
1helpful
2answers
I can't find the safety key for my Weslo Cadence G40, is there any way I can get it to work?
You will have to purchase a new key unfortunately. First, go to
www.iconservice.com in the replacement parts link. There you can type your model number/model name found on your machine usually on the bottom of bikes and ellipticals, and underneath the belt when the machine is in spacesaver position on treadmills. It will give you a PDF version that you can download for free. You can also call for a hardcopy but it will cost around $20 with tax and shipping. The number is 1-800-999-3756.
2helpful
Lost the key to my weslo candence ct 4.8 treadmill how do i get a new key or get it to run
Call Iconfitness @ 1-800-999-3756
Part #: 208603
Part Name: KEY,CORD/KEY,ASSY
Model: WLTL243080 - WESLO CADENCE CT 4.8 TREADMILL
Part List: #208603 - KEY/CLIP
Top Weslo Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
NOEL
NOEL
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
