Question about Ecg Medical
Atric 300 ecg machine paper feed is too fast
It jams all the ecg information up, like the spped is set at 50mm/sec, but the setting is 25mm/sec...
    New Friend:
  • 24 Answers
To correct the paper feeder error you will have to seek assistance from the vendor. You can't do it alone.
Posted on Jan 11, 2018
SOURCE: Brother Intellifax 2800 Paper Jam Issues
Thanks for the reply. I will probably recycle the unit, it seems to be bottom barrel quality and not worth any effort.
Posted on Sep 30, 2008
yooperbud
  • 8637 Answers
SOURCE: Paper Jam Photosmart C3180
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
  • 16 Answers
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Posted on Jul 22, 2009
  • 13 Answers
SOURCE: Samsung clp 300 paper jams after feeding about
Lift Machine up 4 inches at the front with a thick book.
Paper will now run downhill slightly,
Richard
Posted on Oct 29, 2009
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
GE ekg machine printing to fast. How do I fix?
Make sure your print/record speed is 25mm/sec. Most machines have settings of 50mm/sec or 25mm/sec. I bet yours is set to 50mm/sec. RJ
Apr 25, 2017 | GE Medical
Mac 1200 ekg machine prints out an extra sheet of paper with every ekg
You have the printer set up for the wrong size to paper feed stock. It is probably set up for the Rest of the World A4 size paper instead of US Letter size. This makes the sensor pull another sheet as A4 is a tad longer, but a shade narrower. The sensors work by length.
May 13, 2015 | Medical
Schiller AT 10 German <-> English
hi,
Try the following to change the language to English
Press following keys in sequence
ALT ---> FILT --> 25mm/S --> 25mm/S -->STOP
OR
ALT --> 0 --> 2 --> 2 --> STOP
Mar 08, 2013 | Medical
Whats the size paper
50mm x 100mm
Discount Cardiology sells the ekg paper that you need
Sep 15, 2012 | Life Science Eli 50i Mortara Single...
The schiller At-2 we have in the office is acting up. Model number 021-02609. Office number is 480-889-0508. The paper feeds and doesn't stop were needed and the ECG being preformed on a patient are not...
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
Oct 13, 2010 | Schiller Cardiovit At 2 Light Ecg Machine
AL-800 cannot make copies jam light remains on with no jams
First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
Jan 04, 2009 | Sharp AL-800L Copier
Samsung clp-300 printing
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed
Oct 21, 2008 | Samsung CLP 300 Laser Printer
Thick paper wont print
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed0c16087.jpg
Medical Logo
208 people viewed this question
Top Ecg Medical Experts
tootsie mason
ray gallant
Are you an Ecg Medical Expert? Answer questions, earn points and help others
