I. get something long enough to go through the entire hose.
ii. push through hose as there may be some hairballs in there.
iii. check unit for blockages
if hose is blocked you could also flush it out with high pressure water, then allow to drip-dry.
iv. get a sphynx? :)
Our American bi-color short-hair sheds black& white.
SOURCE: Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
SOURCE: Dirt Devil Feather lite bagless does not have
Based on your description the problem is a blockage in the lower section of the vac
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: I have a dirt devil featherlite bagless vacuum;
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt travels.is the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
SOURCE: Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
