Question about Toshiba e-Studio 350 Copier
Bottom paper tray will not close - Toshiba e-Studio 350 Copier
  • 313 Answers
Check if there is paper stuck behind the tray if not look at rear for the spring that holds ithe tray in position as these can sometimes either pop off and fall to the bottom or snap they are at the back part of the machine if you take the tray out and look along the tray runner the psring is at the end on a little bracket...Good Luck A
Posted on Jul 30, 2009
The HP laserjet 1020 paper tray is not closing
too much paper in tray remove some until door closes
May 16, 2017 | HP Office Equipment & Supplies
My printer Tray 1 won't close. How can I fix this problem?
Typically the issue with these types of printers is that the printers it's on the surface that is on even. Or something has got lodged between the back of the paper tray and this log back in.
Pull the paper tray completely out making sure the paper it's properly in the tray. Then look for parts that look like they are either band or out of place. Then look inside the tray slot to make sure there's no obstructions. If the printer tray is at the bottom of the printer be sure that there are nothing underneath the printer and it sitting on a hard surface.
Feb 24, 2016 | Ricoh Office Equipment & Supplies
What does close the feeder tray mean
The Canon PIXMA iP4000 InkJet Printer has two paper sources for printing. Likely the top feeder tray is not completely closed (it is possible you do not have the printer set up to feed from both which may cause the error).
See the Quick Start Guide and the Picture Below:
Mar 06, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Tengo bloqueada una fotocopiadora Ricoh Aficio 200 con el código sc 506 necesitaría un código para desbloquer o reset el equipo
paper tray 3 motor error .. take the bottom cover off..open paper tray and then look at back and get another to close the tray check if the springs are broken or check the motor turns and lifts the tray up..
Jun 08, 2010 | Gestetner Office Equipment & Supplies
The paper tray will not close.
Remove the paper cassette and reform the metal plate at the bottom of the machine. This may take many tries.
The two plastic buttons on the paper tray must slip into the cutouts on the metal plate. Also make sure your machine in not too close to the wall.
it sounds dumb, but i've seen this.
May 21, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Where is tray one?
I reported the same problem and decided to check one last time before I scrapped the printer. I pulled out Tray 1 (the bottom (large capacity tray) to really check closely. I discovered that there seemed to be a space between the end of the paper and the printer tray. I simply squeezed the space closed and NOW IT WORKS! I keep kicking myself for being dumb.
Jul 11, 2008 | Brother HL 1850 Laser Printer
Minolta cspro ep2010
Do you have two trays or four trays for the paper? If you have four and the display is showing the bottom door is open... turn the copier off and disconnect the bottom two trays and turn it back on..... Just use the top two paper trays.. Or the problem is that a acturator is broken off the side door, look for any broken pieces of plastic. Also, recheck for any jamed paper left in the copier.Good Luck
Jun 12, 2008 | Office Equipment & Supplies
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Toshiba e-Studio 350 Copier Logo
66 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
