Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
B&D GH1000 GrasshogXP: I broke the orange colored plastic cap that covers the spool that hold the line. I Have replacement Part #90540850 "SA Spool Housing" that includes orange cap, spool, and new black receiver with 'trigger'. But trouble installing. I cannot remove the existing black receiver after removing the screw. HOw do I remove this old receiver? Note: The new orange plastic cap's 2 plastic tips are slightly larger than the original, so I cannot simply snap in the cap only. Need to install the whoe SA assembly.... I am also open to taking this to a local repair shop for B&D if nearby to Manassas, VA.
  • lmrobinson96 Jul 29, 2009
    Teh 3 repair shops you gave for B&D are on the opposite side of DC from me, over 1 1/2 hours drive into Maryland. Anythink closer in VA?
    President:
  • 1,714 Answers
I have the manual for you here and it shows you how to remove it! YEAAAA!!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/1005667-00,GH1000.pdf
Posted on Jul 30, 2009
    President:
  • 1,734 Answers
I would take this to a B&D repair shop.
Here are the adresses and locations of the B&D shops next to you.
Posted on Jul 29, 2009
I NEED A SPOOL COVER WHERE CAN I GET IT ?
How to make a spool cap cover for an American Gardener YS24 (Weedeater XLT24) Trimmer
If you've tried to buy parts lately for your trimmer, you've noticed they are harder and harder to find. In fact, I was unable to find a spool cap cover, so I came up with this work-around.
Before you start this project, it's important to save any parts from the old spool cover-especially the top, if you can. The top is needed to make a spacer for the new cover that will still allow you to "bump" out the string.
I used a Craftsman 71-64215 replacement spool retainer to make my new spool cover cap. It fits the Craftsman C3 19.2 volt 74381 String Trimmer (CRAC06540 spool cap). I found this cap at a local Ace Hardware, but apparently it is also getting hard to find-I googled the Ace Hardware number to find it on the web-"7314644 cap." I bought a couple extra from HardwareDistributors.com. Note that the diameter of the cover at the tabs is the same diameter of the old cover-although the diameter of the cap is slightly larger.
Take the old cover, and using the tab from the old cover, mark a line on the new tabs the same width as the old. Make sure you center the old tab on the new tab so you will remove the same amount of plastic from each side of the new tab. I used a dremel tool with the cutoff wheels to cut the tabs on the new cap to the same size as the old cap.
If you look at the new cap, there is a round plastic circle ridge on the bottom of the cap. If you look closely you can see a slight indention, or discoloration on the top of the new cap matching the circle on the bottom. You need to cut the plastic out of the new cap matching the plastic circle. I used a dremel tool with a metal cylindrical grinder to do that.
Once you get everything cut, put the old cap into the new cap so that the spokes face down toward the similar spokes on the top of the spool. You may have to trim the old cap so it fits into the new cap.
Finally, snap everything together into your trimmer-don't forget the spring. Note that the new cap has about a 1/8 inch gap above the spool. However, this doesn't seem to affect the trimmer-and you can still "bump" the head to eject the string.
Apr 27, 2015 | American Gardener Get the lower price on...
Need parts for American Gardner Yardstick model YS24. Specificly the line head assembly.
Sep 01, 2013 | Weedeater Garden
Need instructions on changing the spool on electric grass trimmer/edger
Turn the trimmer over, I put it in my lap.Remove the orange spool cap by squeezing with thumb & forefinger. It will come right off. Remove & discard(there has got to be something they can be recycled as?) If you are right handed, hold the new spool firmly with left hand with flat side with the arrows up, keep a firm grasp & use small needle nosed pliers(I use hemostats) etc. to free the loose end of the line where it is looped thru the 2 slots. Keeping hold of the spool so it doesn't all unwind, let enough out to feed thru the hole on the side of the compartment where the old spool was. 2-3" will be enough. Then, place the spool into it's compartment with the flat arrow side up.Keep a good grip on the spool until you get it into place. Replace the spool cap by aligning it in the 2 slots that it came from & gently squeezing again until it locks into place & you are set to go. Don't worry about feeding the line out to proper length, it will do that all by it's self.
Aug 03, 2013 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Can't remove spool from Black & Decker GH1000 weed wacker
UNscrew the cetral screw with a flatheaded screwdriver, then put the flate blade of the screwdriver in through the side slot where the cap clips in, and gently pry up on the spool from underneath it.
Sep 03, 2010 | Black & Decker 14" Grass Hog Xp...
GH1000 Motor runs but spool just quit working.this is electric.
Same thing happened to me. The belt broke. You'll need to take off all the screws to change the belt. There's a hidden screw under the black label. Feel around for the soft spot.
May 21, 2010 | Black & Decker 14" Grass Hog Xp...
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Broken spool cap
I would say yes, here is a site for parts, if this is not helpful please specify your model number
http://www.toolpartsdirect.com/blackdecker/blackdecker-41.html
also here is the actual black and decker parts site.
http://www.blackanddecker.com/CustomerCenter/Parts.aspx
Jun 01, 2009 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
83 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
