Question about Little Giant Submersible Sump Pump, 1/4 Hp
Little Giant Pump - dialectic oil to use
I have a 1/6 hp oil sealed motor on my Little Giant utility pump. I need to add oil to it, but do not know what grade or where to purchase.
  • 2,760 Answers
Ck your local yellow pages for an electric motor repair shop they should be able to get silicone oil to add , but in a pinch ive used full synthhic auto transmission oil that works too
Posted on Mar 05, 2015
2 Suggested Answers
  • 990 Answers
SOURCE: need to add oil to a little giant pond pump
If you have to add oil it is time to replace pump.
Posted on Aug 25, 2009
How to disassemble Little giant pump model#psm006?
thats why i like the little giant pumps they are put together with phillips screws not glued like them other guys , i do suggest that if you dissasemble pump and water has gotten inside , replace it not just seal it up and go , wont last long as that means the pump shaft seal has leaked , ther e has been a few folks that add dietary mineral oil to the inside , for use in very deep ponds (over 3 feet) they believe that helps keep the water out
Jun 11, 2014 | Little Giant Submersible Fountain Pump
My Little giant wgp-65-pw has tripped my gfi repeatedly. any idea why? No shorts in the cord are apparent
if a pump connected to a gfci outlet trips , then the gfci has detected a high resistance "shortage" inside pump and has disconnected power , this "shortage" can be nearly in detectable from human standards(shock) , but gfci picks it up
most likely pump seal has failed and water has gotten inside pump !! it only takes one drop to do this !!
Dec 24, 2012 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
How do you add oil to a sump pump? Do you add it to the water in the pit?
dont add oil to water-- if u have to or want to oil motor get a spray lube unplug unit and at bottom remove debris guard only clips on and spray shaft and behind impeller if need to lube upper motor bearing unscrew housing and carefully pull up enough to lube top of motor replace housing careful of watertight seals and test pump oil poured into pit would only be pumped out and does not contact motor which sits in watertight housing
Jan 25, 2010 | Little Giant Submersible Sump Pump, 1/4 Hp
What oil can I use to top up the motor on a Little Giant NK1
Submersible pumps usually use #10 non-detergent oil.
Oct 12, 2009 | Plumbing
Pump turns on and off every couple of minute, need pump to run non-stop
contacts are bad if you can fis it you will have to go to either a granger store or ele motor store to get them,, make sure they are in in the right direction or it might be easier to change the pump to a new one
May 12, 2009 | Little Giant 5-ASP, 1/6 HP, 1200 GPH -...
Pump is leaking oil
very iffy to get to seal properly and for the $40 bucks cheaper to get new one
Apr 29, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Little giant submersible water pump (model 5-mspr) is low on oil...what type of oil should I use to top up the oil level???
You can use a dielectric oil available at most motor repair shops. It is of the utmost importance to make sure the cord seal is in good condition and well sealed
Apr 22, 2009 | Pool & Spa
24HR working pump question
Utility Pumps: Utility pumps draw water through openings that screen out debris. When placing one into a pond, use a pump sock or other enclosure to reduce the amount of cleaning needed. If you use a pump sock, be aware that sock-like screening can cause a dry pump situation. Solids Pumps: These pumps draw water through a large opening and pump small debris through without clogging. For this reason, they can be placed into a pond without prefilters. Note, however, that this type is not safe for ponds with fish, frogs or other aquatic animals
Aug 27, 2008 | Little Giant Submersible Sump Pump, 1/4 Hp
Little Giant Submersible Sump Pump, 1/4 Hp Logo
1,013 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Jim Goldsmith
Jim Goldsmith
Mike Squire
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
