SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
SOURCE: Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
SOURCE: Samsung SyncMaster 710N Monitor SLEEP MODE
The monitor is not going to sleep the power supply board is shutting down.
If you can solder you should be able to repair the monitor yourself.
The problem is caused by blown capacitors on the power board. Go to our
web site at : www.ccl-la.com/badcaps.htm
We have pictures of what to look for. Open your monitor and look at the
power supply board for any blown capacitors, replace all that you find.
The replacement parts can be ordered from several places on the
internet or we can supply them for you. The replacement parts will need
to be high temp and will be marked 105c. The values you need to get
will be marked on the sides of the ones you take out but will be
something like 220uf, 470uf, or 1000uf etc. and then a voltage rating.
When you install the new ones be sure to insert them with the polarity
stripe going the same direction as the old ones come out. If you don't
want to do the repair yourself we do offer a repair service for $35
plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
