Question about Crafts & Hobbies
How do Imuse markers with my cricut machine? - Crafts & Hobbies
    New Friend:
    Problem Solver:
  • 15 Answers
It depends on the machine the expression 2 the expression and the little machines use markers that fit into the blade housing slot. The explore machines use special markers put out by cricut or there are some called slick writers that fit in the accessory clamp.
Posted on Jan 12, 2018
2 Suggested Answers
SOURCE: My cricut machine won't cut the paper
I am having the same problem...did you have any luck solving it?
Posted on Jun 08, 2010
Will cricut explorer one run on a dual core computer
Ask the maker.... "Contact us" on the website:
https://shop.cricut.com/en_ca/machines/cricut-explore-air.html
"Contact us" is way down on the bottom in the small print. Good luck.
May 23, 2017 | Core Computers & Internet
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    Cricut machines power supplies
    18 volts is the voltage and the thing that is most critical to stop the machine burning out.
    The 'A' - amperage is the force behind the electricity, 2.0 is a sort of fairly strong person 2.5 amps is a muscle man.
    If the piece of equipment needs a muscle man to move it and you use a weaker person, it may not move quite so fast. Good analogy?
    Anyway, .5 amps is not going to make that much difference.
    Jun 26, 2016 | Cricut Expression Cutting Machine
    Black plastic blade arm broke on cricut, where do i get replacement part
    Sheila,
    After much useless searching and an hour on hold with Cricut support, I finally got an answer. It would seem that the cradle arm is not a replaceable piece. Cricut can not supply anything to fix the problem. However, I have found that if you can get the cradle arm back into position you can lock it into place with the thumb screw. It will still hold the blade housing and marker/pen housings, you just have to be careful when removing them to make sure you don't damage your project. Hope this helps.
    Jul 25, 2012 | Cricut Expression Cutting Machine
    Is there a replacement strip for under the slide
    http://www.cricut.com/shop/#0/1/349/3/Cricut/Cricut%20Expression%20Machine%20Replacement%20User%20Manual
    This has a list of all the replacement parts on the left side.
    Mar 09, 2011 | Cricut Expression Cutting Machine
    How do you put the cricut together?
    I would contact Cricut there are no end user serviceable parts to this machine.
    Jan 18, 2010 | Provo Craft Cricut Disney Font Cartridge
    Jpeg file onto a cricut
    Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
    Dec 02, 2009 | Provo Craft Cricut Disney Font Cartridge
    Cricut Expressions Machine error
    1. Make sure your cricut is off when you plug it into your computer via usb.
    2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
    3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
    4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
    5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
    6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
    Hope this helps you.
    Jun 10, 2009 | Provo Craft Cricut Disney Font Cartridge
    Crafts & Hobbies Logo
    206 people viewed this question
    Top Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Craft and Hobby Expert? Answer questions, earn points and help others
