Question about Bunn (279000002) Coffee Maker
How do i calibrate my bunn machine?
Our old macjine had a set option on the inside which put the machine into calibration mode. the new machine i have does not appear to have a set button. so how do i calibrate it?
    President:
  • 1,618 Answers
Check the board on the machine there is a set lever on the right side and instructions on setting on the front cover panel.
Posted on Jul 30, 2009
What is calibrate compass on 2004 Buick Rendezvous
Manual Compass Calibration If the compass appears erratic and the calibration symbol does not appear, you must manually put the compass into the calibration mode. To get into this mode, do the following: 1. Turn the ignition on and cycle the DIC to the compass/temperature mode. 2. Press and hold the SET button for longer than three seconds. ZONE # PRESS & HOLD SET TO CHANGE: This display mode will be displayed when you are manually calibrating the system. The current zone number for compass variance will be displayed in place of the # symbol. Use the SET button to select the zone number from the graphic shown to select the current area of the country that you are driving in. PRESS SET TO CALIBRATE COMPASS: After selecting your zone, press the MODE button and this will be displayed on the DIC. Press the SET button and complete three 360 degree turns in an area free from large metal objects. The following two messages will toggle in the display until you calibrate the compass: • DRIVE VEHICLE IN CIRCLE • CALIBRATING COMPASS When calibration is complete, the display will return to its normal mode. 3-61 info obtained from MANUAL OWL
press the helpful button and follow me on fixya for more tips
Compass Variance Zone Procedure DIC Compass Driver Information Center DIC...
http://www.manuals365.com/swf/buick/2004_buick_rendezvous_owners.html?page=200
http://repair.chiltondiy.com/Buick/Rendezvous/Repair-Manual-Online
http://www.repairservicemanuals.com/Buick
Feb 02, 2016 | Buick Cars & Trucks
What is calibrate compass on 2004 Buick Rendezvous Vous
Need to calibrate bunn mcp. Help?
This model of brewer doesn't allow for changes in the calibration. If you've been using it for a while and notice a change in volume chances are the brewer needs to be cleaned. Here is a link to the full manual. http://www.bunn.com/pdfs/manuals/41980.0000.pdf
Feb 04, 2014 | Bunn My Cafe MCP
How do I calibrate the machine to brew longer so that it will fill the pot completely? It doesn't have the knobs on the inside like our other one
If you in fact have the "no timer knob" models there should be instructions just inside, on the panel on how to adjust the brew level. The important part is to make sure the switch on your timer board is in the "set" position.
Apr 29, 2011 | Bunn (CWTFTWIN)
Wont vacuum
With machine power OFF,remove old pressure transducer & replace new one.now power ON the machine & go for calibration.Calibration step for Robinair 34700Z machine.Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
Hope this will solve you
May 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
How do you calibrate a new internal scale in a modle 347002k/replaced scale now I need to calibrate it before putting machine back in service.
From the main menu go to change default option,press 5454 then press enter key.after access to default nenu you have to select calibrate scal option.press again enter key then follow the on scree message.NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.once you done so,press stop key to complete the prcess.
Jul 16, 2009 | Robinair Cool Tech 34700Z Recovery,...
How do I recalibrate it?
From main menu: go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.once you done so,press stop/exit key to complete the prcess.
Jul 16, 2009 | Porter Cable Measuring Tools & Sensors
Do you know how to calibrate the scale?
Jun 25, 2009 | Robinair Cool Tech 34700Z Recovery,...
Color
You may need to calibrate the scanner. This should be able to be done in the Advanced Mode of ScanGear. ScanGear is the scanner driver. Once in Advanced Mode, locate the option to Calibrate under the Image Settings section.
Jul 02, 2008 | Canon CanoScan 4400f MultiFunction Color...
Bunn (279000002) Coffee Maker Logo
859 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
