Question about Samsung CLX 3160fn All-In-One Printer
Samsung CLX 2160 "paperjam2" problem
My CLX 2160 printer is showing the error message "scan unit open or paperjam2". I have checked everywhere and there is no paper jammed in the printer. I have opened the back, checked underneath (tray feeding area) and opened the front. There is no apparent paper jam. I have also cleaned all the rollers I can see. None of this has fixed the problem. Any solution would be greatly appreciated.
  • 92 Answers
Hi ...
IN CLX 2160, paper jams usually occur in three areas of a printer. The following error messages indicate the area in which the jam has occurred:
  • Jam 0 indicates the paper failed to pass through the first sensor.
  • Jam 1 indicates the paper failed to pass through the second sensor and has jammed around the toner cartridge.
  • Jam 2 indicates the paper failed to pass through the second sensor and has jammed near the fuser.
Your error shows paper jam2 but i am giving you directions to fix the paper jams indicated by each error message so that you can handly any kind of paper jam issue with your printer.
Paper Jam 0 When your printer displays Jam 0, paper has failed to pass through the first sensor.
To remove the jammed paper, follow these steps:
  1. Power your printer off.
  2. Open the cover of your printer.
  3. Gently pull the paper toward you to remove it from the printer. Note: If you do not remove the paper slowly, you can damage the printer and the printer will require service.
  1. After removing the paper, make sure there is no additional paper in the paper path.
  2. Close the printer cover, and then power on your printer. Samsung CLX 2160
If your printer still displays Jam 0 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 1 When your printer displays Jam 1, the paper has failed to pass through the second sensor and has jammed around the toner cartridge.
If your printer still displays Jam 1 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 2 When your printer displays Jam 2, the paper has failed to pass through the second sensor and has jammed at the fuser.
  2. Close the printer cover, and then power on your printer.Samsung CLX 2160 "paperjam2" problem - jam%202.jpgspan>jam%202.jpg
If your printer still displays Jam 2 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Please vote if this helps ... Cheers :)
Posted on Jul 29, 2009
  • Curtis Dose Dec 17, 2013
    I had the same message and looked everywhere for the jam, front (cartridges out), back, bottom paper out), top and had given up. I was actually shopping on line for a new printer when I saw a photo of the scan unit open exposing the fuser area with a lower door open. I opened the scan unit (top) and looked more closely at the bottom of the top. A slotted door the width of the paper track opens on the bottom towards the rear. Under it I found an 8x10 sheet of paper folded tightly like a Japanese fan. I coaxed it out of there and printer is perfect again. Look again!
Get the error message at a samsung 2160 printer: error deve home-sensor. What can i do..........
Dear
Deve Home Sensor Error indicates a problem in the fusser unit.
Unplug the power cord ,check the fusser unit and plug it back in.
If the problem persists, Replace to the
Main board.
Jan 16, 2011 | Samsung CLX-2160N All-In-One Printer
Non-working printer; no paper pickup
The solution shown for the Samsung CLX-3160FN All-In-One works also for the Samsung CLX-2160N.
The associated picture and methodology of "pre-stretching" the solenoid spring is virtually identical for both printers.
Worked for me on the CLX-2160N
See here
http://www.fixya.com/support/t4742967-deve_home_sensor_error
Jul 07, 2010 | Samsung CLX-2160N All-In-One Printer
I bought a Samsung CLX 2160 laser color printer about 2 years ago and since some weeks I get an error message '' low heat'', no printing is possible since then. where is the problem and how can I solve it?...
The "low heat" error indicates a problem with the printer's fusing unit. Turn the machine off, unplug it from the wall, then plug it back in and turn it on. If the error shows up again, you'll need to call a service technician to come out and either repair or replace the fusing unit.
Jun 16, 2010 | Samsung CLX2160 Multifunction Color Laser...
Transfer belt error samsung CLX-2160 help
The first thing to try is to turn the printer off, unplug it from the wall, then plug it back in and turn it on. If the error message goes away, you can resume normal operation. If the error message still appears, you'll have to call your service technician.
Feb 09, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-2160 aste tank is full
On the drum unit, the bit that the toners go in is the drum it is a unit off to the side of it, heres a pic of the waste unit...
Jan 14, 2010 | Office Equipment & Supplies
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Samsung clx-2160
Hi I asked about the CLX-2160 NOT the SCX-4100  I have had no replies yet
Regards
Anthony Showman
Nov 09, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
3,769 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
