We moved so it was layed on its side to emty out the water and now it wont fill up and wash so what can I do?
SOURCE: washing maching won't continue cycle
Check that the front door or lid interlock switches are operating. If they are not, the machine will not start. It is a very common cause of non-operation, and simply opening and closing the door will usually clear the problem if it is just intermittent sticking.
SOURCE: Washing machine wont circulate the clothes, the thing inside wont move
Check the belt, either loss or broke
SOURCE: washer will wash but will not advance after draining wash
Very likely a dead spot in the timer, but check the lid switch (bypass it is best) to make sure it in not working intermittently. Hope this helps!
SOURCE: Have a super heavy duty washing machine, it fills
Bad timer most likely. Here are some repair photos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Admiral Capacity Plus Washer -
This is
almost certainly the result of the fill sensor failing. intermittantly
Essentially, the sensor is a bellows device. A pipe is connected to the device and as water reaches the end of the pipe and advances up it, the air pressure in the pipe increases, inflating the bellows. As the bellows inflate, they press on and trip a microswitch inside the sensor and cut the power to the water inlet valve, stopping the water flowing into the machine when it reaches the correct, measured level according to the pressure in the pipe.
Take the top
off the machine, if you look down the side you will see a (typically clear
plastic) tube about the thickness of a pencil, connected to a circular device
about the circumference of a coffee cup and about an inch to two inches thick.
This is the
sensor. Problems with it may be:
It has come
unclipped from where it should be mounted. The device is VERY sensitive and if
it has slipped out of place, over or underfilling is common. (Reposition the
sensor, hopefully you can see where it came from!)
The pipe
that is connected to it has come off, so the air pressure that the sensor
measures is not increasing as the machine fills (push the pile back on and all
is well)
The machine
has been subject to some trauma (Such as a very uneven load that has made it
shake violently. The starting level of the water that is in the bottom of the
pipe is now wrong and the pressure sensor is being affected. (Remove the pipe
from the sensor, blow down the pile to get any water that should not be there out
and then replace the pipe).
