Question about Sony Ericsson K608i Cellular Phone
Sony 6081 not switching on
My sony ericssonk608i will not turn on, batt,goodcharger good
  • 5 more comments
  • prateado Jan 12, 2008
    I have the same problem. I already bought a new batery but nothing work!
    Can any one help?
  • kayez Feb 12, 2008
    my 608i wont switch back on
  • Mohsin Malik Feb 22, 2008
    My sony k608i is not switching on. Battery is fine. How can I flash it?
  • vinerz07 Mar 10, 2008
    my phone fell then i switched it off.later when i tried to turn it on it never responded.
  • Anonymous Mar 27, 2008
    wont open
  • Anonymous Aug 12, 2008
    I am unable to switch on my cell (K608i).
    When I tried charging the cell, it worked fine (though I could not access the menu), but when I unplugged the charger, the cell automatically switched off.
    When I gave it to nearest sony ericsson service centre, I was told that the problem is with the motherboard.
    Motherboard replacement would cost me around 75% of the cost of the cell!!!!
    Please let me know if there is any solution existing to this problem !!!!
    Thanks in advance!!
  • baaaaaby Oct 25, 2008
    Take out the battery, Plug in the charger & then put the battery back in.
    It turns on for me! .. but I have a problem with the phonebook.. it doesnt
    load, and all my numbers are on the phone & not on the sim..
  • 192 Answers
You are requested to see semiler problems and their solution here. You will find it as written for you.
Posted on Jan 09, 2008
WillNot start batt., good starter, good all fuzzes good
If the engine is not cranking over, it could be the clutch safety switch
(standard trans), Neutral safety switch (automatic) or ignition switch.
If the engine is cranking but not starting, it is not the starter, battery
or alternator. Check fuel supply, ignition and compression.
Sep 27, 2012 | 1997 Chevrolet Cavalier
I got the code C:31:22 flashing on the screen. what should i do?
this error pertains to one of the reels (the thing that turns the tape)is malfunctioning.so most likely you'll be having issues w/recording,playing,fast forwarding or rewinding the tape.you can try RESET (press the reset button located inside and beside the eject button in the tape compartment cover, while cam is on).if it doesn't work try POWER RESET (turn cam off,remove the batt,make sure the ac adaptor is not connected.turn power switch to camera or player, and leave w/o power for at least a minute.turn power switch back to off and reinsert batt.check if working).if still you get the error,repair might be needed.hope this helps.thanks:)
Apr 06, 2010 | Sony Handycam CCD-TRV608 Camcorder
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Need A/V cord for Sony TRV68
i have a sony TRV 12 E which is not getting switched on even by AC power and even when i remove the batt pack. can this happen if batt pack is fully discharged? should i change the batt pack.?
pks65@hotmail.com
Oct 20, 2008 | Sony Handycam CCD-TRV68 Camcorder
Phone
It is phone's generic software problem. It occures while we mis-handle it. There are some doe's and don'ts with this type of device. Generally it occures when we snached out battery while it is in on possition (active mode). This action corrupts it's software files and not putting them back where it should be after power off. For fixing your problem you have to reflash it. Any technician with smart tools of sony-erric can do it you. ASK fixya for nearby repairman and do vote here....
Nov 23, 2007 | Sony Ericsson K608i Cellular Phone
HDR-HC1 power keeps cycling
I had this exact problem, and the cycling would stop after about 30 sec. and then function properly. I believe a circuit was confused, mainly because I used an older battery and let it run out till the batt was dead - accidently - and when I put in a fresh batt, it no longer cycled and works perfectly to this day.
Now if I can get my computer to recognize the camera via firewire, I'd be golden.
Mar 07, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Sony Ericsson K608i Cellular Phone Logo
62 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
