Question about Remington Electric Pole Saw
I detached the pole and cannot figure out how to reattach it. The online manual does not show any instructions for this
  • 157 Answers
The pole will go back on but you may have to twist it or maybe look and see if theres a groove it fits in
Posted on Sep 18, 2009
How do you set it up
Check your manual, or look for instructions online, but the basic plan is...
1. Lay it out so the door faces where you want it.
2. Stake down the corners, yes- even if it is 'free-standing' you usually want to do this.
3. Figure out where the poles go. They usually go through cloth sleeves, or metal rings, or clips or something. They also go in arcs that may or may not cross at the top. (a manual REALLY helps with this!)
4. Slide a pole in place. if it goes through a sleeve, you usually slide it in first, then stick the ends of the poles on little metal studs at the corners. If it clips on, you usually build the pole, then run it from stud to stud, then clip the tent to the arch you made.
5. Repeat for all poles
6. Pull the rain fly in place, clip on at each pole end and as needed.
7. Pull out and stake other ties as available. This gives you more interior room, more stability and protection in weather, and improves ventilation.
May 30, 2014 | ACADEMY BROADWAY CORP Camping, Backpacking...
C846 hard to pedal
follow this instruction. God bless you
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Jul 21, 2013 | Precor C846i Experience Series Commercial...
When the cam is put on recordning mode a error on the screen shows the following- eject sign followed by ...D , On top on screen its written EJECT LP
The error display shows that the camcorder has some mechanical fault.Follow the instructions below.
1. Eject the Tape
2. Set to OFF
3. Detach the battery
4. Reattach the battery
5. Power ON as usual
Simple faults will be recovered when performing the above procedure.Good Luck
Jun 04, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
Hello. I have a disney princess bed tent that my daughter recieved for christmas. We went to go and set it up and the instructions are missing. Is it possible to get a copy faxed/emailed to me?
I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
May 19, 2010 | Toys
Get my HP 6127 to pring double sided ... I when through the set up but it prints one side of the page upside down
Do you have the separate duplexer accessory unit properly attached onto the rear of the printer? If so, detach, reattach and try again. If unsuccessful, make sure your print command dialog has the proper settings under "Preferences" before you click on PRINT. Here is the guide online: http://h10032.www1.hp.com/ctg/Manual/bpd09860.pdf
Apr 26, 2010 | HP DeskJet 6127 InkJet Printer
The rear view mirror assembly has detached from the roof of the car. How do I reattach the stem in my 2003 Honda Element
just carefully pry the finisher from around the mirror stem and remove the screws . if the stem base is broken you can buy a new one from your local honda dealer here's the instruction from the manual e5f525b.jpga09abf3.jpg
Apr 01, 2009 | 2003 Honda Element
Model 106890-02
Here is a link for instructions how to attach a pole to the saw...
http://12.153.20.74/manuals/111006-01A.pdf. I hope this helps. If you need parts for the saw you may want to call Master Parts at 800-446-1446. I hope this helps.
Mar 15, 2009 | Remington Electric Pole Saw
Remington Electric Pole Saw Logo
107 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
