Question about Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor
Ingersoll-Rand DD2T2 air compressor
Looks like one side of the compressor lost a bolt (or something), the hole looks like something screwed into it. When I turn on compressor, the tanks will not fill and air is coming out of this hole. What is missing?
    President:
  • 1,167 Answers
Hi mate its either a fitting off the tank and it is just pumping air into the tank and out the hole or its the mpv valve this stops air in the tank bleeding back to the pump so when the pressure drops it can start other wise it wud not start as the piston is not possible to go up this is why when the compressor stops it bleeds off air in the system but to be honest i need more information to figure out what it could be e.g is it on pump unit or on tank etc
Posted on Aug 08, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Looking for parts list. missing strart capasitors etc.a manual or schedule can help me out.need to buy some parts ingersoll rand dd2t2
Hi johnny camer.
Sorry I could not find a parts list for your compressor model
But I found the ingersoll rand contact number, you can call them and talk to them on the net and get the right parts and manual you need.
Please take time to rate me
http://www.ingersollrandproducts.com/IS/Category.aspx-am_en-31052
Aug 31, 2011 | Ingersoll Rand DD2T2 T Win Stack Single...
I have a ingersool rand DD2T2 and oil is in the air lines what is the problem?
Hi melissa, my name is John. Welcome to FixYa. Try bleeding the tank, loosen the valve at the bottom of the tank and drain it. Let me know how it goes. Thanks for choosing FixYa.....John
Dec 02, 2010 | Ingersoll Rand DD2T2 T Win Stack Single...
How i can connect electric motor in to air compressor 230 volt hp7.5 hp1
A motor like that will require a motor starter, you cannot use just a pressure switch cause it draws to many amp's
Jan 29, 2010 | Ingersoll Rand DD2T2 T Win Stack Single...
I have the Ingersoll Rand Model # DD2T2, WAS WORKING GREAT, NOW IT HAS STOPED WAS THROWING BREAKER IN SWITCH BOX NOW IT HAS STOPED ALL TOGETHER, MOTER CAN BE TURMED BY HAND BUT WILL NOT RUN AT ALL.
If the motor turns by hand, but the breaker is tripping does not preclude a bad motor. Could be nothing more than a capacitor on the motor itself. If the breaker you speak of is on the unit itself, could be bad. If it is in the electric panel, motor capacitor is the first place to look.
Jan 16, 2010 | Ingersoll Rand DD2T2 T Win Stack Single...
Owners maluel
I could not find your model number as typed, however, this link will take you to Ingersoll Rand website where you can click on rotary or recpiprocating compressers for a list of available model manuals.
http://www.irtechpubs.com/index.cfm?fuseaction=view.main&type=Compressed%20Air&cat=206&sub=933
Nov 23, 2009 | Ingersoll Rand DD2T2 T Win Stack Single...
Ingersoll Rand SSR-EP75 owners manual, I need to remove the cooling fan and replace it , its on a marathon electric fan motor e206, motor is good but the plastic blades around it are busted, I need info on...
The pulley is held on by a compression type of coupling. Loosen all the screws in the coupling. Remove two screws and they should thread into two or more threaded holes in the coupling. These are holes that should be 180 degrees apart....they will be the only holes threaded. If all the other bolts in the circumference are loose you should be able to thread these two bolts into the coupling and the bolts actually "jack" the coupling apart. The coupling and fan should easily come off the front of the motor. The motor should be held on by 4 screws to the motor tower in front of your air/oil cooler.
Aug 19, 2009 | Ingersoll Air Tools & Compressors
A lot of water in air line
You have to drain the water with the drain valve on the bottom of the tank
Aug 08, 2009 | Ingersoll Rand DD2T2 T Win Stack Single...
Ingersoll rand compressor oil leak (Model DD2T2, 4.5 Gal.)
The brass fitting that goes into my DD2T2 seems to have a hole in it and it looks impossible to remove without ruining a major gasket due to the close tolerance in replacing the fitting. Am I missing something?
Mar 09, 2009 | Ingersoll Rand DD2T2 T Win Stack Single...
Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor Logo
123 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
