Question about AKG C3000B Professional Microphone
I have an AKG C3000B microphone. It got very quiet.
I have an AKG C3000B microphone. In the middle of a song it went dead. (I may have bumped it with my guitar, but not too hard at all.) It works a tiny bit if the volume on the mixing board is turned to max. Please help. Thank you.
  • dave350 Jul 29, 2009
    Thanks for the feedback. But when my mic went "quiet" I used another mic in its place and it works fine. The trouble is definitely with the mic itself.
How to repair a C3000B with low output.
I had the same problem, and was able to repair it myself. i've seen several other posts with the same description, and if you can use a soldering iron, you're golden. I just now repaired mine, and it took less than 10 minutes. One of the leads going from the PCB board to the capsule was broken loose at the solder joint. Mine has been dropped, so no surprise. Somehow, if you boost the signal enough, you still get sound, where I would have expected silence.
You need a star bit set (I have a little mult-mini screwdriver set that has them stored in the handle from home depot.) There are two silver screws in the bottom lip. Remove these and the whole screen housing slides off. Even better, the capsule assembly slides out too. There are two prongs that plug into a harness when inserted.
There are two black wires from said prongs to capsule leads. See if one is loose. If so, solder that ***** back on and its as good as new, and hot signal.
You also need small plyers, someting to strip the small. I know this is a late post, but maybe it will elp somone. Good luck.
Posted on Jan 02, 2010
  • 1 more comment
  • Lukas
    Lukas Jan 06, 2015
    Thank you soooooooooo much Bwoods1!!!! That was my problem, too! I opened my C3000B but didn't see that small... one was broken. Soldered it and the mic is still good at a zero cost! Yours was a late post but helped me 4 years later!!!! Thanx a lot!
  • Lukas
    Lukas Jan 06, 2015
    4 years later? No, 5!!!! :)
  • Julien Pierre
    Julien Pierre Mar 30, 2015
    Thank you very much ! Was able to fix mine that had been dropped and stopped working. Just like yours, it was still producing some output when turning the preamp volume all the way up. Very odd. But now it's back !
    Problem Solver:
  • 12 Answers
Sounds like the connection to your preamp was severed. What pre are you using? Or what interface? Have you tried physically pushing the mic cable all the way back into the mic and the other end back into the interface or preamp? Follow the signal all the way from the mic to the computer and secure every physical connection. See if that solves it.
Posted on Jul 29, 2009
Barely has any output. i thought it was low battery but it was not. what could the problem be?
If this is a (phantom) mic, it has to be plugged into a phantom plug on a mixer (round black thing with 3 metal posts in the middle. Darren Kelly-themasterofthrowdown@yahoo.com
Apr 28, 2011 | AKG C1000S Professional Microphone
I have three working AKG C1000S. They all need grills. Who can I trust to service or sell grills?
AKG sells the replacement screen and tube assembly direct from AKG Acoustics, U.S.
+1 818-920-3237
akgusaservice@harman.com
They are expensive, $80.00 each.
Oct 25, 2010 | AKG C1000S Professional Microphone
Akg c3000b Low output all of a sudden
Buy the Caig Labs De-Oxit kit and clean up/treat the XLR connections on the mic itself.
Apr 27, 2017 | AKG C3000B Professional Microphone
I have a slight hum in this mic. have swapped cables, mics, et. It definately comes from this mic this is the original C3000 (black) not the B model.
Try the mike on another PA. Sometimes power phantom do weird things with electrical installations hum on the line. Let say commercial fridge.
Aug 05, 2009 | AKG C3000B Professional Microphone
Microphone cuts out
If you tried other cords and other PAs the problem might be in the jack where the cord plugs into the mike. service@akg.com might also be able to give you more info.
May 18, 2009 | AKG Perception 200 Microphone
C 518 ML Isnt Working
Make sure that you are supplying phantom power. This mic requires it. Without phantom power, the mic will appear to be dead.
Let me know if that resolves the problem.
Dan
Mar 19, 2009 | AKG C 518 ML Microphone
My mike just stopped working, dead?
The first thing to check is the phantom power. Make sure it is there. The mic will appear dead without the power present.
Dan
Apr 07, 2008 | AKG C414BULS Professional Microphone
Help with AKG shock mount H-100 parts
I kept messing with it till I got the right combination. It works fine now.
Thank you,
Mar 19, 2008 | Audio Players & Recorders
AKG C3000B Professional Microphone Logo
1,865 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Ben Armstrong
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
