SOURCE: the shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
SOURCE: zoom error on fujifilm finepix J30/35 how can i fix it?
If this is a brand new camera, it should be under warranty...why do you say yours is not?
SOURCE: fujifilm instax 200 camera will not spit out pictures! :(
Link
Camera might be damaged because of the fall, suggest to consult the Authorized Dealer near you (-see above link), or send it back to the store where you purchase it as it may be still part of the warranty.
Thank you
SOURCE: I have a Fuji Instax
The same thing happened to me. Make sure that the mechanism arm on the inside that pushes the picture up is connected with the metal piece on the right hand side. The two can come loose allowing the metal piece to not bring the arm with it when you take a picture. Also the roller could have fallen down a bit. From the inside, press the roller up (it will click when it is in the right spot). The roller should be even all the way across and pushed all the way to the top of the camera.
I hope this helps if you haven't been able to fix it already.
(When all else fails, try changing the batteries.)
SOURCE: fujifilm A345 keeps saying zoom error lens wont
I recently came into this camera and after a day of testing it, it's doing the same thing. My work around is this. When it's on I press the zoom function and the lens then pops out. Then after it's out, I remove the batteries while it's still on. Put the batteries back in, and power it on (lens will be popped out) and then it starts working. I only paid $7 for it at a good will. So I was taking a chance it worked somewhat. This may work for you temporarily. Not sure how long this one will last.
