Question about Whirlpool Duet GHW9150P Front Load Washer
(I have a Whirlpool Duet Sport) I cannot get the door locking mechanism to unlock the door no matter what I do. I just tried unplugging it for 45 minutes to see if I could reset the CPU(?) but I plugged it back in no change.
  • scottododd Jul 29, 2009
    Hey thank you for that response, sounds like like some good advice.
    The plot thickens a bit - my wife informs me that the washer made a very loud noise prior to seizing up. Does this information indicate or imply that I have an expensive fix (say, water pump) in my near future?
  • 6,784 Answers
HI. i have posted a procedure that will help you unlock this door and , it will also lead you to a secret tech sheet hidden inside the lower panel. This sheet will help you in the future with unpublished trouble codes and solutions as well. First, you must unplug the machine.
Next, remove the lower front kick panel. You will need a star-head driver (six points), which you can get at your Sears store. It requires a fairly small unit. I used an interchangeable handle with swappable parts to match the right size head.
The three star-head screws are located along the bottom of the kick panel. If the washer is sitting on the optional pedestal, be sure to pull the drawer out before proceeding. Then unscrew each of the screws and place in a plastic bag to avoid losing them.
The front panel is now attached by pressure to the rest of the washer. Take a crowbar or any slim tool to pry open the panel. Cover the end with a thin paper towel to avoid scratching the paint on the washer, insert the thin end low in the gap between the washer and the panel, and gently twist until the side pops off. Do both sides.
Once the panel has been removed, look to the right on the side of the inner wall of the washer. There you will find the lost manual pages intended to help the tech interpret error code and fix conditions. It also contains instructions on how to (((UNLOCK THE DOOR))). Take the manual pages out from behind the plastic envelope (they are taped and sealed, be careful not to tear them) and put them with the rest of the user manual, where they belong.
You can now see the inside of the washer. Look up in the inside where the latch for the door closes. You will see a small plastic black box. Pull the bottom end straight down. Then, open the door.
Posted on Jul 29, 2009
  • Michael Masters
    Michael Masters Jul 29, 2009
    It depends on what the noise actually sounds like. if it was a grinding noise, this will lead to a frozen or , damaged pump impeller. you will need to replace the pump in this case.
    Now, if it was a slight or heavy click or metal sound, this will lead to the motor/pulley assembly. i would suggest to inspect the belt to see if its still on the pulley securely and, the drum should be moved with only slight resistance. if the drum cannot be moved and, the resistance level when moved manually, is high, this will confirm electrical motor issues.
  • Michael Masters
    **NOTE_-((that noise can come from the door lock assembly as well. the Actuator will make a noise when defective)).
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool duet washer is locked. I tried holding the end of cycle button for 3 seconds, and for 15 seconds with no luck. Any other solutions?
there is a fault on the machine try unplugging for 1 minute the plugging back in it may unlock if it does don't try to use it it will only do it again till problem corrected if this doesn't work remove the 3 screws from the top panel slide back and up right below the door lock there is a little pull down lever it is attached to the door lock mechanism pull it down to unlock
Jan 29, 2014 | Whirlpool duet Washing Machines
F-22 is my error code. What is that?
F22 DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Possible Causes/Procedure
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Nov 25, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Brand NEW Whirlpool Duet Sport
After six failed attempts by your machine to lock the door F22 flashes.
Causes & Procedure:
Door switch or door unit failure.
1 Unplug / disconnect washer.
2 Check door switch lock unit.
3 Check wire harness connections to door switch/lock unit & the
Fault 22
Push the door to make sure it is locked firmly (try some WD40 on the door mechanism on machine, not on door, to ease out any lock jam & try the door open/close with the power off the wall) I'm giving you tips to avoid the so-called techs zooming for your wallet.
Fault 28
The communication between the CCU & the MCU (motor control
unit cannot be sent correctly.
1 Unplug washer / Disconnect power
2 Check wire harness connection to the MCU, the motor & CCU
Check communication of the CCU board within the housing.
Make sure all grounding switches are engaged.
3 Check the drive system for any worn or failed components
4 Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
5 Verify CCU operation by running the Diagnostic Test or any
cycle after plugging in.
Will try getting back re the door lock. Desperate i know, so am i.
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET WASHER 9150 DOOR LOCK DOES NOT UNLOCK
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
replace door lock and ccu sorry
Jul 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
We just had a flood in our basement and our Whirlpool Duet Sport HE front load washer is displaying F28 which I know means something electrical. Is there any way I can disengage the electronics to get the...
Unplug the machine. Remove the bottom access panel (three torx screws along the bottom). Reach up under the area where the door lock is and feel for a round door release mechanism. Pull down and the door will unlock
Jun 08, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
