SOURCE: fujifilm instax 200 camera will not spit out pictures! :(
Link
Camera might be damaged because of the fall, suggest to consult the Authorized Dealer near you (-see above link), or send it back to the store where you purchase it as it may be still part of the warranty.
Thank you
SOURCE: The neck ******** my fujifilm
The film had a leader, which is meant to be sticking through the top of the camera. The only thing I can figure you can do is to take the film out of the camera, in dim lighting or a dark room, if you have one, and reinsert and guide the film pack in correctly.
There's no guarantees that the film will be good anytime a camera has been opened, but it might, so it's worth a try. What have you got to lose...
Good luck, hope this works for you, and thanks for using FixYa.
SOURCE: I just loaded my new
Well, black prints on an instant, or any camera, mean that they're unexposed. So, there are a few things to check - but in your case all will probably mean losing your remaining photos.
First, when you loaded the film, did you remove, or did the camera spit out, the initial black cardboard leader? If not, this is the source of your problem. This piece must come off the film pack first otherwise nothing else is going to work.
If that came out and you're still not getting photos, you're going to need to verify that you're both using the camera properly, and that the camera is functioning properly.
You'll need to be sure that you're getting enough light to get a good photo - darkness isn't going to give a good picture, but in some situations with some high speed films, neither is too bright of a condition. I've had this problem with my polaroid camera. The camera can't compensate for an extreme high-speed film and bright sunlight so it's not even giving an exposure. Don't ask me why, but it happens. If there's an option to change settings for outdoors/indoors, try that.
If that's also not your situation, you'll need to find a way to verify that the camera's shutter is actually opening and working properly. That's easier said than done, but if the other two situations don't help, feel free to contact for further assistance.
SOURCE: I put a fresh new
try to take a few more photos or try use pack of films.
If same things happen, mean the shutter lens is spoil. it don't allow light to enter and develop the films.
Send it to repair shop to fix it
SOURCE: My Fujifilm Instax Mini 20
I have the exact same problem
have you figured out how to solve it?
