Question about Music
My Roland TD6 drum module output jacks have a bad hum and cut out
The 60hz? hum happens and it will hum loud and cut out. Wiggling the cables at the back of the module helps, but it keeps happening. The cables are good and I've tried others. I sprayed contact cleaner, but still have the problem. What is needed to repair these jacks?
Thanks,
John
  • 313 Answers
Sounds like the solder on the connections has either dried and cracked or come loosse if the wrigling of cables works its the connections if you unpluig and remove the back panel look where the cable connect check the condition of the wiring at source point of contact you may need to resolder or reconnect..
Posted on Jul 31, 2009
I have roland cube20x. I makes a loud buzz when plugged a cable on the input jack but it goes down when i touch the jack. Thanks
You have a ground problem. I suspect your cord. Replace it, being sure you use an instrument cable, and see it that doesn't help.
May 01, 2017 | Roland Music
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
No pad sound
Not sure what module you're using this with, but I'm familiar with Roland electronic drum pads and modules, and guess the following would stand true for any pad / module combo....
I would check the following:
  1. Is the cable correctly connected at the pad?
  2. Is the cable correctly connected at the module?
  3. Is the module sound turned up?
  4. Are your headphones / speakers turned on & up
    (do other pads sound)?
  5. Is the fader for the specific pad (or pad group) turned up?
    (On a Roland module, where the pad is AUX1 to 4 - the 'fader' button needs to be pressed in order to operate the AUX slider).
    The next couple of things are less likely, but possible.
  6. Does the pad have a polarity switch on? - try switching it.
  7. Has he correct pad type been assigned in the module?
  8. Has an instrument been assigned to the pad
    (Roland: Press INSTRUMENT, hit the Pad, select a sound)
If you get no joy with this - please drop me a message.
Dec 30, 2012 | Alesis e Practice Pad Electronic Drum...
FCan get my Ipod to play through my Roland TD-20 Mudule
You need to get yourself a cable - with a 3.5mm male jack plug on one end (which will fit into your ipod), and a 1/4 inch male jack plug on the other end.
(you could use a lead with a 3.5mm male plug on each end, and used a 3.5mm female to 1/4 inch male adaptor to achieve this)
Connect the 3.5mm end into the ipod - play a track, with the volume at say, 75%.
Connect the 1/4 inch end of the cable to the 'Mix In' input in the back of your TD20.
Use the 'Mix In' control - at the top right hand side of your TD-20 module to control the volume.
If you wish only to have the iPod going to (for example) headphones - and not Front Of House (PA) speakers - which you will have connected via the Master and / or Direct Out(s); this can be achieved in the 'Mixer' settings (accessed via pressing the 'Mixer' button).
Oct 22, 2012 | Roland TD-20X V-Drum Sound Modul
D-drums t d 4 roland no loud in the headfons
you may need to access menu to increase volume output through headphones
Jul 10, 2012 | Roland Music
Best way to connect two electronic drum modules together
use one MIDI cable connected to MIDI Thru jack
Jun 17, 2012 | Roland Music
Headphone jack will not send audio through any cable. There must be something wrong with the motherboard chip.
Did you check the solder connection on the jack where it connects to the motherboard? That's a high stress point and could simply be a broken contact that needs to be resoldered. Should be 3 or 4 pins likely.
Aug 30, 2017 | Roland TD9 Drum Module
My Boss RC-2 Pedal is having a problem with the output. With the volume turned up to max, the signal is suddenly extremely faint on can only be heard if there is silence in the room. Even the backing track...
Most PROBABLE is the output jack either has been broken (common due to mishandling and accidents with cables such as stepping on the plug while plugged into the pedal) or the soldering of the jack in the pedal has broken loose. Less common is a circuit board crack in the vicinity of the jack. Open pedal and inspect for the above suggestions.
Mar 11, 2011 | Roland Boss RC-2 Loop Station Stompbox...
The headphones output on my roland td- 10 is sending sound just to a single channel ,I test it with diferent headphones ,same thing.
The owners manual is here:http://lib.roland.co.jp/support/en/manuals/res/1811143/TD-10_eG.pdf Try initializing the TD-10. Check page 137. Check page 132 and 133. If the problem is still there, you likely have a jack problem. There might be a bad solder joint where the jack is mounted to the circuit board. If the warranty is up you can do it yourself if you are confident. Otherwise take the module in to have it serviced. Check here to contact Roland:http://www.roland.com/index.html
Aug 31, 2009 | Music
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Music Logo
216 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
