Question about Canon PowerShot A85 Digital Camera
All pictures with flash come out underexposed and can hardly be seen.
  • 300 Answers
Hi!
It sounds like the flash unit has to be replaced - I have seen problems like these with these cameras and changing the flash unit helped. I'm afraid you won't be able to repair it yourself. You should contact your local Canon service center.
Hope this helps!
Tom
Posted on Jul 29, 2009
How do I fix the flash on my Sony A390?
Sony eSupport - DSLR-A390 - Support
https://esupport.sony.com/.../model-find.pl?...DSLRA3...
Sony CorporationModel # DSLR-A390 ' change model. ... not go away · The background of a picture is dark and underexposed when using a flash. ... My A7R II is dead... or is it?
A390 flash not working. - Sony's Community Site
https://community.sony.com/t5/Alpha-SLT.../A390-flash-not.../437652
Sep 2, 2014 - My sony A390 onboard flash is not working not matter what setting I use. what can be done to fix this?
B
Dec 02, 2015 | Sony alpha A390 14.2 Mp Digital Slr Camera...
When my OM-D 10 is in "P" mode the flash fires but the pictures are very, very dark, obviously underexposed. What's wrong?
"P" mode in most digital cameras is, "Program", meaning that it's really kind of manual. Attempting to shoot flash in this mode is likely to be difficult. Suggest "A", or "Automatic" mode.
Oct 31, 2014 | Olympus OM-D E-M10 16.1 Megapixel...
2nd picture in a series is often underexposed and sometimes blurry what can we do?
If the first picture used the flash and you immediately took the second picture, the flash wasn't completely charged and either didn't go off or was very weak.
Oct 24, 2009 | Panasonic Lumix DMC-FX8 Digital Camera
Faces show up dark and unrecognizable
How far away are the faces? The flash on a typical point and shoot camera has a very short operating range, typically 3 to 15 feet. If something appears in the picture ahead of the faces, the flash will shut down prematurely and underexpose the faces.
Aug 12, 2009 | HP Photosmart R847 Digital Camera
Problem with underexposed pictures
I've got the same problem with my new ef 500 dg super and my ef 530 dg super. It occurs on all nikon camera's I could get.
D70, D80 and Fuji S5 Pro. I don't have this problem with an old (4 years) sigma ef 500 dg super.
I will try to contact Sigma for this problem.
Nov 01, 2007 | Sigma EF-500 DG for TTL Flash
Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Sep 25, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Underexposed, grainy images with a light stripe running down the center
Sounds like your shutter curtain is malfunctioning. Did you bump the curtain when u loaded film & bed it... Take a close look to see if it is binding. This is a very fragile area to monkey with & should be done by a qualified repairman
Jun 26, 2007 | Canon EOS Rebel K2 35mm SLR Camera
Portraits underexposed
Whenever you are taking pictures of people within six feet of them, it is a good idea to turn on the flash - whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the right arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Outdoor portraits underexposed
Whenever you are taking pictures of people within six feet of you, it is a good idea to turn on the flash whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the up arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Pictures are underexposed
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture. When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light. If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Canon PowerShot A85 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
