Question about Crafts & Hobbies
How can I hook two trains to a Lionel kw 195 transformer no accessories
    Top Expert:
  • 8,387 Answers
Posted on Nov 19, 2017
Testimonial: "Thank you, I did a search initially but I didn’t see this one thanks again"
  • NOEL
    NOEL Nov 19, 2017
    you are very welcome glad i could help you out.
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
  • 2418 Answers
SOURCE: The Cw 80 watt transformer
If you have a volt meter you can check the rails for power, Check the transformer wiring to the first rail connection and then along the rails for loss loose connection(s). If you have power to the rails it is an issue with the Engine, Check any brush or rail riders (connections) for a bent or broken tab. If for a temp fix in a broken connection tab or brush you can use Tin foil. Hope this helps.
Posted on Dec 25, 2010
  • 10 Answers
SOURCE: No longer have manual for
See link below to PDF file with instructions to your transformer. It looks like you are correct with regards to the wiring with what I can see in the manual.
Hope this helps and good luck
www.lionellines.com/files/manuals/KW_Manual.pdf
Posted on Aug 04, 2011
  • 13 Answers
SOURCE: is lionel 40 watt transformer from toy train
need a larger out put transformer 90 watt or greater....
Posted on Nov 20, 2011
SOURCE: I am trying to hook up a Lionel 1033 transformer
I have the original Instructions for Operating the 1033(written in 1953) - the second paragraph of the "How To Connect Transformer" reads as follows: The "Multi -Control" transformers listed in this leaflet have four binding posts located on the top of the transformers. Of these, "A-U" and "B-U" combinations furnish variable voltage for the track. The control arm of the transformer simultaneously regulate the voltage output of both the "A-U" and the "B-U" combinations. The transformer nameplate indicates the voltage ranges of these two combinations.The "A-U" combination supplies any voltage from 5 to 16 volts. The B-U combination has voltage from 0 to 11 volts. In selecting the proper range of voltage for your particular outfit, try the lower "B-U" combination first. If the maximum train speed is not satisfactory, then try the "A-U" posts.
To paraphrase the "How to Connect Accessories" section: accessories work best with fixed voltage - these voltages are obtained from the following pairs of output binding posts: "A-B" 5 volts; "B-C" 11 volts and "A-C" 16 volts.
Hope this helps, Mark
Posted on Dec 06, 2011
How to remove the red handle and how to get to the fuses
You can't. These transformers aren't user serviceable. You can thank the Federal Government for that. If you can find the special tool to remove the case, you'll be able to open the transformer. For service, contact Lionel customer service or take the transformer to a Lionel Service Center.
Aug 14, 2015 | Lionel Cw 80 Transformer
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
Can I use the cw-80 transformer on any Lionel train set from year 1948 to the preasant , thanks George
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
Feb 05, 2011 | Lionel Cw 80 Transformer
My lionel rw transformer won't run the train unless ithe speed control is turned 3/4 way up or better . Can this be fixed ?
Yes. Find a Lionel repair shop or bring it to a local hobby store that does model train repairs. You can contact Lionel for a list of repair shops.
Dec 25, 2010 | Lionel Cw 80 Transformer
The green light on the transformer isn't going on
The Green light on, But flashing and the train don't move
Nov 15, 2010 | Lionel Cw 80 Transformer
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
I have a lionel legacy cab-2 remote i hooked up every thing to the manual but when i turn it on i dont get any track power
just unplug the transformer from the grey box (the one with the green light and red light) and check the voltage. if it doesn't read anything, try unplugging the transformer from the outlet and plugging it back in again. if you get a reading, replug the transformer to the grey box and check the voltage of the silver screws (where you put the + and - wires from the track to) and try using the train again
May 30, 2010 | Lionel 14295 990 LEGACY Command Set V2
Crafts & Hobbies Logo
162 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
