What’s wrong with it exactly? You need to be specific with your questions. If it’s torn, you can buy some adhesive paneling material that you cut to shape and apply to both sides of the sail. It works fine for most cases, however the laser sail is quite large in terms of ratio.... boat:sail size. That means high sail pressure in lighter winds.
Your best bet it to take it to a sail maker for repair.
Ulman sails
North sails
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/taylor_e81897e2b9d82155
You do not need a license to sail your Yacht. However, if it
is not yours and you are renting it, you may need a sailing license or some
sort of certificate that proofs that you are capable of sailing the boat.
Also keep in mind that this may differ from country to country so you may want to double check.
A Yacht is any propelled boat that exceeds 32 feet in
length, and weighs less than 300 gross tons.
