Have a 36 foot carrie lite. bought it used. when the temp is over 100 degrees its around 90 degrees in trailer. not a fun time. works great at night. do we need to replace the unit or get it fixed or is this the max this unit will cool. if so it out of here. we live in texas and it gets hot.
    Genius:
  • 1,341 Answers
You don't need to replace this item as it can be fixed.Work out the cost of labour etc + parts and if it sounds too costly then maybe you are better off with a new one.Now many of these systems needs re-gasing to be back to work,so it is worth trying to check if there is gas( freeon) in it.Based on a rate loss of 10% per year,work out how old it is and a bit of math will prove you that you probably just needs re-gas to be back on and perfect. Now it might be some other problems but as you mentioned it's a 2nd hand item then it's a high possibility this is the cause.
Posted on Jul 29, 2009
Mq whisperwatt 25 k with izuzu engine has new airfilter good on fluids good air flow fairly balanced on 3 phase 240 between 32 amps and 36 amps all legs. running hard at like 1700 rpm supposed to be 1800...
Although packing it in dry ice could be an option I would recommend checking the thermostat and the coolant pump. Check to see if the hoses have pressure in them by gently squeezing them just as the engine is warming up. 100-105 degrees. Be careful after that. If you don't have callouses ;) Good luck
Joe
Feb 18, 2011 | Diesel Electrical Supplies
Hi i have a Hobart Beta-Mig 200 and i need a all new gun and wip.
Hobart machines now belong to miller brand, you can use a miller gun M15, no need for adaptors it's a direct plug connection. Praxair stores carry a cheaper gun under prostar label a 150amp gun will cost you around 150 bucks.
Oct 27, 2010 | Hobart Welding Tools
I have a 1999 volvo s70 non-turbo 2.4 5 cyl. I bought it 1 year ago with 124k. It runs great, but the a/c cuts off when it gets over 90 degrees. At freeway speeds, it stays on (until it gets around 100...
There have been a lot of problems with the compressor cutting out when it gets hot. When the A/C begins to blow warm, check the power supply wire to the compressor. If there is power in the wire, you will most likely have to replace the compressor. If there is no power, you will have to trace it back to see what the problem is (a wiring diagram will help greatly).
Jul 01, 2010 | 1999 Volvo S70
Outside air temp around 100 unit wasnt cooling good noticed evap coils dirty cleaned them cooled alittle better checked low side showed 90 lbs had friend reclaim to get it to 70 lbs 30 minutes later it...
90 psi suction too high possible bad valves or non condensablies in the system (AIR) what is the head pressure and what type of freon r-22 410-A? your unit is never shutting off watch out for that electric bill. and did you take apart the condenser and clean it? Tom
Jun 25, 2009 | Heating & Cooling
Frig warm
unthaw the fridge ice is blocking air flow to the fridge section
Jun 21, 2009 | Dometic RM2652 Refrigerator
Jetta 2003 TDI
My mechanic in our town did a quick computer check. Car computer indicated a low level of antifreeze, he topped it up, cleared all messages off the car computer and said to watch the the heat guage for any further irregularities. I'll keep an eye on it, love the car, great mileage fun to drive.
Nov 05, 2008 | 2002 Volkswagen Jetta TDI
Our 4 yr old refridgerator & freezer quit working. power was on because the temp indicators showed 48 & 28 degrees. Should be 36 and 1 degree. We moved all of the food out and obviously temps...
These unit normally, if frost free model has a defrost cycle. It is possible that at the time you noticed it the system was in its defrost mode.
Jun 09, 2008 | Refrigerators
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
