Nowadays, it comes a common sense to add a BIOS or Windows password for laptop protected. Thus, a feasible advice is to create a Windows password disk in case that you forgot Windows password. But without Windows password reset disk, what should we do in order to
bypass Windows password?
It's time to learn how to
bypass Windows password with the following two tips and tricks.
Method 1: Bypass Windows password by Safe Mode with Command PromptAccording to Wiki, Safe Mode is a diagnostic mode of a computer Operating System (OS), a special way for Windows to load when a system-critical problem interfering with normal operation of Windows. If you are not able to boot your computer in normal mode or supposed your notebook is infected with Trojans or malware, you are able to get rid of them with Safe Mode. Furthermore, it is easier and safer to
bypass Windows password in Safe Mode when you lost or forgot Windows password.
Take Windows 7 for example: there are 3 different types of safe mode: Safe Mode, Safe Mode with Networking, and Safe Mode with Command Prompt. Below is a guide on how to bypass Windows 7 password with
Safe Mode with Command Prompt, which allows you to bypass Windows password with command line. Detailed steps are as follow:
Step 1. Boot or reboot your Windows 7 computer.
Step 2. Press F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Step 3. Choose Safe Mode with Command Prompt in the coming screen, then Press Enter.
Step 4. Wait for Windows 7 files to load until Windows login screen comes up.
Step 5. Log in with an administrator account when you see logon screen.
Step 6. A Command Prompt appears.Type net user in the Command Prompt and then hit Enter. All Windows user account names will be listed for you.
Step 7. Type net user 'Alina 123' and hit Enter.
Step 8. The new password has been successfully reset when the command is completed successfully.
Step 9. Log on your PC with the new password.
Note: 'Alina' is your locked Windows user account name. And '123' means the new password you want to reset for the locked account.
Whenever you need to log on to Safe Mode, an administrator account password is necessary. So it is highly recommended you to write Windows password down and sotre it or creating a Windows password recovery disk before lost/forgot Windows password.
Method 2: Bypass Windows password with Windows Password UnlockerHowever, if you haven't created a password reset disk and forgot all administrator account password, it's better for you to bypass Windows 7 password with Windows password reset software. These reset software allow you to bypass Windows passwordwith a USB flash drive or bootable CD/DVD.
Windows Password Unlocker Professional is one of the best choice to reset or change Windows password in a while.
Go through with these steps and recover Windows password with ease!
Step 1.
Download Windows Password Unlocker Professional and install it in any computer.
Step 2. Run the program and burn an ISO image file into a blank CD/DVD or USB flash drive.
Step 3. Start your locked computer from the bootable CD/DVD or USB flash drive.
Step 4.
bypass Windows password successfully.
Of course, there are some other methods of
bypassing Windows 7 password. Picking up a suitable and efficient one to bypass Windows password is a necessity.
